Will SLP dual inlet CAI work with a MAF setup?
Old Feb 13, 2002 | 05:33 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I was wondering, does anyone know if the SLP dual inlet CAI will work with a MAF setup? I mean, SLP's site lists it for my car when i put in the '87 model year, and '85-87 came with MAF didn't they? Maybe there's some kind of kit that it comes with to relocate the MAF... Anyone?
Old Feb 14, 2002 | 02:43 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Um, no it won't work, here is my setup and look at the Throttle Body and the front of the SLP intake. There isn't any space for a MAF there,
If you convert to Speed Density like I did, then you can.
I have an 86 Trans Am converted to MAF TPI then to Speed Density.
Old Feb 14, 2002 | 05:15 PM
Hg's Avatar
Hg
Car: '87 Z
I figured... thanks anway. I was just wondering cause with their single inlet one I think you can still have MAF...
Old Feb 14, 2002 | 05:53 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Dam those are cool looking. Zepher, do you think a MAF sensor would fit in between the TB and the duct? Would you be able to measure the distance between the two without the rubber ducting in place? It looks like a MAF sensor could fit in between the duct and the TB if some of those rubber couplers where used. Thanks
Old Feb 14, 2002 | 11:13 PM
Zepher's Avatar
It didn't fit when I put my MAF over the rubber boot part. But I'll measure it again tomorrow to give you an exact measurement.
Old Feb 15, 2002 | 11:22 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Thanks, i'd appeciate that. I wonder if it would fit if I used some of those rubber couplers trimmed to te proper length.
Old Feb 15, 2002 | 02:26 PM
Zepher's Avatar
I think you'd have to actually trim the MAF ends to get it to fit.
I'll measure it today when when I do some work on the car and post the measurements this evening.
Old Feb 15, 2002 | 02:31 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Cool, thanks.
Old Feb 16, 2002 | 06:24 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I think length wise it would fit, but it needs the rubber boot to go from like a 3 inch circle to the big oval for the TB. If the boot is too short it won't pull over the TB.
Old Feb 16, 2002 | 06:55 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
That's what I was thinking. Hopefully if the space between the MAF and SLP duct is kept to an absolute minimum, the coupler will be able to transition from a 3 inch circle to the TB. Maybe it would be possible to use an aluminum adpater like an exhaust reducer. I'd just like to ditch the factory setup on my GTA.
Old Feb 16, 2002 | 07:06 PM
Guest
Guest
Posts: n/a
If you use one of those round rubber couplers thats big enough to fit over the TB inlet it doesnt work very well, been there done that. You really need something thats oval shaped to begin with.
Old Feb 16, 2002 | 07:19 PM
STOCKROC's Avatar
miniram?
Would the maf clear with a miniram. The miniram tb is located further back than on a stock tuneport.
Old Feb 17, 2002 | 06:20 AM
Zepher's Avatar
Didn't have a chance yesterday to measure it, too busy. I should be able to measure it today.
I'll find out about the Mini-ram as well, a couple of my friends have Mini-Ram'd SBC400's in thier Camaros.
Old Feb 17, 2002 | 12:11 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Zepher...did you have any problems with relocating the battery? Any hot start problems? I like Slps setup but IM unsure about relocating the battery.
I need a higher flowing air intake just not sure what to run yet.
Old Feb 17, 2002 | 02:44 PM
Zepher's Avatar
No problems with relocating the battery, car starts just fine, battery charges good, just need to get a battery box to securely hold the battery down.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
onefreakz
May 14, 2018 12:15 PM
NBrehm
Aug 25, 2015 11:49 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
