305 or 350?
Old Feb 20, 2002 | 11:38 AM
camaro_iroc_87's Avatar
305 or 350?
hey guys,
i just picked up my iroc a few months ago from a guy who used to own a body shop on the eastern shore of maryland. the car was involved in a front end collision with a motor cycle (ouch, i know, but it's cleaned up nicely and the title's clean too) now for the problem - when the acciedent happened, the engine was knocked around a bit and so the guy decided to replace it with one he had from a formula lying around with low miles on it. he put the engine in, it runs fine, and he swapped the gauges too...the thing is...they're the 145 mph gauges that, correct me if i'm wrong, only came on the 350 cars? other than that, i have no idea how to check is there anyway i can find out for sure what it is without ripping out the engine and checking the numbers behind the block? i figured this belonged in the tpi boards...the car is tpi, but if not, my apoligies. thanks in advance.
~`tristan
Old Feb 20, 2002 | 01:10 PM
tpi_roc's Avatar
If you're the guy that just entered the chat and talked to me for a few..
I ran your numbers, its a 305 block
If you're not the guy disregaurd this.
Old Feb 20, 2002 | 01:29 PM
ya, that was me, thanks
Old Feb 20, 2002 | 03:24 PM
AggieZ28's Avatar
I have 145 mph gauge on my 305tpi but it is a 91. I think they put the 145 guages on 91 and 92.
Old Feb 20, 2002 | 03:35 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You can't swap guages from a firebird into a camaro BTW...
Old Feb 20, 2002 | 09:05 PM
Bird_of_Prey's Avatar
Car: Formula
Engine: 400 sbc
my 87 formula has a 145 speedo (220 km/h).. 305 TPI auto..
Old Feb 20, 2002 | 10:46 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
TPI got 145, TBI got 120, CARB got 85. not sure on v6 120?
Old Feb 21, 2002 | 07:56 AM
89 rock's Avatar
hey
hey guys.....i got a 89 iroc-z 1le with a 305tpi 5spd and it says 240km/h on my speedo.....
Old Feb 21, 2002 | 11:39 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
My 87 IROC 305 TPI has a 145 Speedo. The 85 TPIs got a 85 mph speedo.
Another way to tell is the redline. The 350s had a 5500 rpm Redline. The large cammed 305 also got this same redline, but I'd say a majority of the 305s got the 5000 rpm redline.
Old Feb 21, 2002 | 02:16 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Depending on the year, you might be able to tell what engine it is by the Speedo /tach setup.
Scroll down and you can see what my research has turned up. This info is from the firebird parts & illustration catalogs...
John
<body>
<p style="margin-top: 0; margin-bottom: 0"><font size="6">87-92 Speedometer/ Tachometer Combinations Does not include
Digitals</font></p>
<hr>
<p style="margin-top: 0; margin-bottom: 0"><font size="6">1987</font></p>
<div align="center">
<center>
<table border="1" width="90%">
<tr>
<td bgcolor="#FFFF00" height="15">
<p align="center" style="margin-top: 0; margin-bottom: 0">Engine</p>
</td>
<td bgcolor="#FFFF00" height="15" align="center">
<p style="margin-top: 0; margin-bottom: 0">Transmission</p>
</td>
<p style="margin-top: 0; margin-bottom: 0">Speedometer</p>
</td>
<p style="margin-top: 0; margin-bottom: 0">Tachometer</p>
</td>
</tr>
<tr>
<td height="16">
<p style="margin-top: 0; margin-bottom: 0">305 LG4 (4BBL)</p>
</td>
<td height="16" align="center">
<p style="margin-top: 0; margin-bottom: 0">A4, M5</p>
</td>
<p style="margin-top: 0; margin-bottom: 0">85 mph</p>
</td>
<p style="margin-top: 0; margin-bottom: 0">5000red / 6500max</p>
</td>
</tr>
<tr>
<td bgcolor="#FFFFCC" height="16">
<p style="margin-top: 0; margin-bottom: 0">305 LB9 (TPI)</p>
</td>
<td bgcolor="#FFFFCC" height="16" align="center">
<p style="margin-top: 0; margin-bottom: 0">A4</p>
</td>
<p style="margin-top: 0; margin-bottom: 0">140 mph</p>
</td>
</td>
</tr>
<tr>
<td height="16">
</td>
<p style="margin-top: 0; margin-bottom: 0">M5</p>
</td>
</td>
<p style="margin-top: 0; margin-bottom: 0">5500red / 8000max</p>
</td>
</tr>
<tr>
<p style="margin-top: 0; margin-bottom: 0">350 L98 (B2L) (TPI)</p>
</td>
</td>
</td>
</td>
</tr>
</table>
</center>
</div>
<p style="margin-top: 0; margin-bottom: 0">&nbsp;</p>
<hr>
<p style="margin-top: 0; margin-bottom: 0"><font size="6">1988 &amp; 1989</font></p>
<center>
<table border="1" width="91%">
<tr>
<td width="23%" bgcolor="#FFFF00" align="center">
<p style="margin-top: 0; margin-bottom: 0">Engine</p>
</td>
<td width="18%" bgcolor="#FFFF00" align="center">
</td>
<td width="20%" bgcolor="#FFFF00" align="center">
<p style="margin-top: 0; margin-bottom: 0">Rear Gear</p>
</td>
<td width="10%" bgcolor="#FFFF00" align="center">
</td>
<td width="30%" bgcolor="#FFFF00" align="center">
</td>
</tr>
<tr>
<td width="23%">
<p style="margin-top: 0; margin-bottom: 0">305 LO3 (TBI)</td>
<td width="18%" align="center">
<p style="margin-top: 0; margin-bottom: 0">A4, M5</td>
<td width="20%" align="center">
<p style="margin-top: 0; margin-bottom: 0">All</td>
<td width="10%" align="center">
<p style="margin-top: 0; margin-bottom: 0">120 mph</td>
<td width="30%" align="center">
<p style="margin-top: 0; margin-bottom: 0">5000red / 6500max</td>
</tr>
<tr>
<td width="23%" bgcolor="#FFFFCC">
<p style="margin-top: 0; margin-bottom: 0">305 LB9 (TPI)</td>
<td width="18%" bgcolor="#FFFFCC" align="center">
<p style="margin-top: 0; margin-bottom: 0">A4</td>
<td width="20%" bgcolor="#FFFFCC" align="center">
<p style="margin-top: 0; margin-bottom: 0">2.73 (GU2)</td>
<td width="10%" bgcolor="#FFFFCC" align="center">
<td width="30%" bgcolor="#FFFFCC" align="center">
</tr>
<tr>
<td width="23%">
<p style="margin-top: 0; margin-bottom: 0">M5</td>
<p style="margin-top: 0; margin-bottom: 0">3.08 (GU4)</td>
</tr>
<tr>
<p style="margin-top: 0; margin-bottom: 0">3.23 (GU5)</p>
<p style="margin-top: 0; margin-bottom: 0">3.27 (GW6)</td>
<p style="margin-top: 0; margin-bottom: 0">140 mph</td>
</tr>
<tr>
<td width="23%">
<p style="margin-top: 0; margin-bottom: 0">3.45 (GM3)</td>
<p style="margin-top: 0; margin-bottom: 0">5500red / 8000max</td>
</tr>
<tr>
<p style="margin-top: 0; margin-bottom: 0">350 L98 (B2L)</td>
<td width="19%" bgcolor="#FFFFCC" align="center">
<td width="31%" bgcolor="#FFFFCC" align="center">
</tr>
</table>
</center>
</div>
<hr>
<p style="margin-top: 0; margin-bottom: 0"><font size="6">1990 - 1992</font></p>
<center>
<tr>
<td width="25%" bgcolor="#FFFF00" align="center">
</td>
<td width="21%" bgcolor="#FFFF00" align="center">
</td>
<td width="22%" bgcolor="#FFFF00" align="center">
</td>
<td width="32%" bgcolor="#FFFF00" align="center">
</td>
</tr>
<tr>
<td width="25%" align="left">
<p style="margin-top: 0; margin-bottom: 0">305 LO3 (TBI)</p>
</td>
<td width="21%" align="center">
</td>
<td width="22%" align="center">
<p style="margin-top: 0; margin-bottom: 0">120 mph</p>
</td>
<td width="32%" align="center">
</td>
</tr>
<tr>
<td width="25%" bgcolor="#FFFFCC" align="left">
</td>
<td width="21%" bgcolor="#FFFFCC" align="center">
</td>
<td width="22%" bgcolor="#FFFFCC" align="center">
</td>
<td width="32%" bgcolor="#FFFFCC" align="center">
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</tr>
<tr>
</td>
</td>
</td>
</td>
</tr>
</table>
</center>
</div>
</body>
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
