Do I need A.I.R???
Old Feb 24, 2002 | 03:15 PM
WS6Formula350's Avatar
Do I need A.I.R???
I'm going to building a miniramed 355 and i'm puttting on SLP 1 3/4 headers. I saw that Resources is running a special on them so i thought i pick them up now. Anyway, would i need the AIR tubes in the headers or not. I don't plan on getting rid of all my emission stuff just the EGR or is the AIR hooked into that? I really don't know here. Also, any thoughts on keeping the emission stuff would be helpful. I know people so it's not a big deal about the EGR or emissions. I'm sure people are gonna so then, get rid of it all but i don't see then need unless it's robbing me alot of hp.Thanks in advance.
Old Feb 24, 2002 | 04:27 PM
89BlueTA's Avatar
I got rid of mine, just for a cleaner look. And more engine comp. room.
Nick
Old Feb 24, 2002 | 07:05 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I hope you dont plan on passing inspection if you get rid of the air.:nono:
Old Feb 24, 2002 | 07:14 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
You CAN get rid of the EGR without getting rid of the AIR stuff.
In regards to the emissions comment, it depends on where you live. Many states in the US don't require the "sniffer" test, only visual inspection. There are many places around where I live here in Missouri that don't even pop the hood during an inspection and I'm sure it's like that in other states too. Heck, I had the last place put my car up on a lift and look under it and not say a word about my cat being gone.
Old Feb 25, 2002 | 08:34 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I dumped my AIR when doing valve seals, and it does clean up the engine compartment nicely. As they do not do emissions testing of ANY variety here, it is just not a problem. The only problem I had was the crossover tube that runs behind the engine, how in hades do ya get that feller out of there without dissassembling the top half of the motor????? Too much stuff in the way. (dist, wiring harness, assorted brackets......)
Old Feb 25, 2002 | 08:15 PM
Kersteae's Avatar
Where I live in Ohio there is only a sniffer test and I've learned that as long as its well tuned and you have a cat, you'll pass. But if you have a vis check too your better off getting the A.I.R. pipes. Later.
Adam
cmro92_rs305
Dec 10, 2004 08:02 PM
IROC Wrangler
Jan 22, 2004 06:07 PM
RED92BIRD305
Mar 24, 2003 09:24 AM
My90Iroc
Apr 20, 2002 03:36 AM
86FyrBrd
Mar 25, 2002 11:23 PM
