I'd like to see actual #'s With smaller runners
Old Mar 2, 2002 | 10:46 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Well I have always heard that for a Forced induction motor With TPI.... it's better to have smaller diameter runners then it is to port them/go to larger casting...due to velocity factors..in effect going to a larger runner and baseplate and Ported plenum it's much harder to maintain higer PSI
So can anyone elaborate or have some good links to support this theory
I have heard it time and time again
but I have personally never seen any factual results before
I mean it makes sence that if you had a higher volume to fill that it will be the case
But how will it compare to a higer flowing intake "Hp wise"
get what I'm saying .. sorry if it's confusing
Old Mar 2, 2002 | 11:01 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I don't have an answer for you, but I do need to get ahold of you. I will be at Famoso around 9am in the morning... Hopefully we can hook up then. I also sent you an e-mail.
Jason Aschle
Old Mar 3, 2002 | 06:09 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
anyone ?
Old Mar 3, 2002 | 11:08 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Hey Jed.
I dunno. i think your right that the smaller tubes will keep up low speed velocity so the intake charge won't stall out. The advantage would be better low end, and since the boost will overcome high end ineficiencies it isn't as much of a problem.
But i really have no clue, but that sure sounded smart eh? later
Paul
Old Mar 5, 2002 | 02:26 PM
esams's Avatar
Damn good question. I wish that Smitty dude with the 10 second, stock runnered 305 would talk with us on this.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
