TPI good enough for 13second 305?
Old Mar 7, 2002 | 08:40 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'm looking to make a 13 second 305, and I'm wondering, is TPI going to be enough to get it to run 13's? I'm not saying like 13.0 or anything, i'm thinking high 13's. I'd be happy with 13.9, but I'd still like faster
Old Mar 7, 2002 | 10:56 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Somebody on this board is running high 12 with the 305 TPI and on the stock bottom w/o power adder. The qoestion is how much money are you willing to spend.
IMO, headers, ported base/heads, custom PROM and an aftermarket cam will make you reach your goal.
Good luck.
Old Mar 7, 2002 | 11:21 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Of course u can get high 13's with the 305!! Start modding.
Old Mar 8, 2002 | 07:37 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
That's what I was hoping last week at Cecil County.Unfortunitely the custom chip made it run slower than the Hypertech stage 2 chip.Waiting on them to checkout chip.
Bill
Old Mar 8, 2002 | 10:19 AM
tpi_roc's Avatar
S/R torquer
(or alum L98)
Old Mar 8, 2002 | 12:48 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
A convertor and gear will get you into the 13's, the intake is not the question on getting a specific e.t.
Old Mar 8, 2002 | 01:55 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Hate to use him as an example because its overused but Preston smith was running in the 9's on a 305 with a tpi UPPEr...still had the stock runners too....BOOST will get you there easy....
Matt 98 SS had his 305 in the 12's with an ATI...
Those are just 2 people who come to mind on that issue...
Old Mar 8, 2002 | 02:18 PM
Administrator
Aren't his runners LTR's??
Old Mar 8, 2002 | 02:20 PM
tpi_roc's Avatar
yup
Old Mar 8, 2002 | 03:17 PM
camaro6spd's Avatar
yes 13 are easy to get out of a 305 TPI(esp a 5spd....like me )
I say
Alum L98 head ported....
A cam like a ZZ4 or 2032 or somthing
SLp runners, everything ported to match and the max
Headers
Cat-back
Ed Write cip for all u non buners out there
what do you say
300 hp
13.8???!! somewhere in there
All u 350 ppl shut-up about if you put that much into a 350 you would be in the 12s....shut-up.
Old Mar 8, 2002 | 04:14 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Heads, cam and runners and i'd run low 13s.
If only i didn't have a vert, i'd love to see how deep in the 13s i can get w/o openeing the longblock....c'est la vie...
Old Mar 8, 2002 | 06:07 PM
Hg's Avatar
Hg
Car: '87 Z
I'm trying to decide on heads right now, what do you guys think is better- S/R Torquer 305's or a set of L98 heads? What is a good price for a set of L98 heads also? Here is what I had in mind, it's all going on an '87 LB9 Z28 w/700R4.
SLP Cold Air Induction
Edelbrock Hi-Flo TPI base
SLP Runners
SLP cam (# 51006 I think it is)
Heads(as above, L98 or S/R Toquer 305's)
roller rockers-anyone recomend a good set?
Port matched(if money permits)
SLP headers and catback(full edelbrock if I can't afford SLP)
**** kit(transgo?)
3.73 rear end
ALOT of spohn stuff
eibach prokit springs, etc etc
What do you guys think this is good for? Hopefully somewhere in the 13's... I've looked at trick flow rr's, and the crane gold race rockers(i think vader was saying they weren't that good... may be wrong though). Can anyone recomend a good set of roller rockers that would work with this stuff? I'm pretty sure I need those self aligning ones 3/8ths right? That's an area where I don't quite know my stuff...
Old Mar 8, 2002 | 09:00 PM
iroc22's Avatar
Check this out:
http://www.nastyz28.com/2gcog/cylhead.html
13's are fairly easy with a TPI 305. Actually 13's should be fairly easy with any 305. Get some relocation control arms for the rear, S/R torquer heads, some good headers and a bigger camshaft. If you're not in the 13's with that you will be pretty close.
Old Mar 9, 2002 | 05:57 PM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
4th Gen V-6's can take out 305 V-8 cars?
I was reading this post over at FvC, alot of these guys think the newer V-6 equipped F-bodys can beat our 305 equiped cars...
I dont see how this is possible, the strongest V-6 equipped 4th gen is the 3.8 powered version with 200hp, not sure of the TQ rating but I know our 305's put out alot more.
Now say you pit a 2002 Camaro 3.8 against a car like mine a 1989 GTA 305 5 speed, if the drivers were equal in skill is it possible my GTA in good tuned stock form could fall to this 6 cylinder in the 1/4?
I own a 1998 Grand Prix GT with the 3.8 it is quick, but I just cant see it pounding 305 equipped TPI cars..
Heres the thread is ya guys like to take a look at the discussion..
http://fordvschevy.com/forum/showthr...threadid=14001
My name their is sportinsco and I stuck up for the 305,, now this aint meant to cause a flaming war, I want to see the opinions on the 305 side of the fence...
Old Mar 10, 2002 | 12:20 AM
zimmer's Avatar
ALL free mods, headers,3'' catback exhuast, K&N airfilter, gears, ignition, torque converter(if automatic), low temp thermostat, synthetic oil and filter, Performance Resource chip, and maybe World Product heads with roller tip rocker arms.
Old Mar 10, 2002 | 01:37 AM
Administrator
It depends on the 305. The only cars that I think have a chance against them stock are the L69's and the 305 TPI 5-Speeds. I can see though that the majority of those on that board know nothing about these cars, or any car for that matter!!
Old Mar 10, 2002 | 11:17 AM
LetsRock's Avatar
I agree with the L69's and TPI 5speed's, those guys ruled out any 305 or at least most of them. If any of em are close enough Ill take em on at the local track with my TPI 5 speed .
Old Mar 10, 2002 | 10:47 PM
iroc22's Avatar
Man that 98gtyellow dude needs a smack in the head.
Old Jan 4, 2003 | 03:10 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
i used to beat the lts autos all day long with my g92 305 5 speed
i can't wait to see what the car is like when i install the l98 w/ the comp 2032 cam in 2 weeks - just praying to the camaro gods my WC T5 holds up...
Old Jan 4, 2003 | 04:06 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Trust me you can go faster than 13:s
Old Jan 4, 2003 | 04:15 PM
STIFFLER's Avatar
If I could get some traction I think I would be able to hit a 13.99
I have the power just no traction...
Old Jan 4, 2003 | 05:39 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
theres a guy running around here i forget his name but i have his file with all his mods...he uses his stock heads fully ported a TPIS l98 super profile cam big mouth manifold large tube runners headers and some ignition mods and hes runnin 12.30's and 11.77 on a 90 shot....stock tranny and read end too
hes puttin down 370 horse and 410 ft pounds to the ground
92 camaro with a t-5..
Old Jan 4, 2003 | 07:45 PM
iroc_cragg's Avatar
I am also looking for the same out of the 85 305 TPI. What do u suggest a good stall speed for a TC would be. I am thinking that a 2000 stall would be good for me. Any advice.
I agree with all the guys here... Headers, Catback, Cam, TC and gears could get u into 13s no prob.
Old Jan 4, 2003 | 09:28 PM
BORLAZ06's Avatar
Originally posted by kane91z
i used to beat the lts autos all day long with my g92 305 speed
tell me bout it...
Old Jan 6, 2003 | 12:17 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
Status: Online
Posted: January 6, 2003 6:21 am Report this post to a moderator | IP: Logged | Post #58
i actually registerd just so i could reply to this post....are u v-6 guys sh!ttin me?...you actually think that u could hang with a g92 305 5 speed? lmfao!!!!!......so ur basically sayin that u could hang with an l98?....obviously your not aware that an l98 and a g92 305 of the same year will run the same times...you cocky 4th genners need to get your head out of your *** and face that fact that u dont have a v-8 and your stuck in 15 second land lol....
just so u know my 91 gta with the lb9 g92 5 speed runs low 14's all day long....with a k&n a flowmaster and some very minor plenum porting.....i guess you guys can beat lt1's huh lmfao.... too too funny
this is what i said about the v6's beating the lb9 lol
Old Jan 6, 2003 | 02:42 AM
BORLAZ06's Avatar
Posted: January 6, 2003 8:41 am Report this post to a moderator | IP: Logged | Post #59
OMG...i cant believe on what i read. a whole lot of sh** talkers..this and that. blah blah blah. But this has caught my attention. If you think a V6 firebird and keep up with an G92 you prolly have some problems. I mean come on, I still have a bone stock, yes 'bone stock motor' no free mods, nada yet people have some serious problems beating me down..damn LT1 guys. And what do those have...hmmm..260 HP compared to my 209 and they still have problems. Of course this is stock for stock. And stock GT's..LOL!!! Let alone a "HO" V6. HAHAHAAAHAHAAAAAAA. If your a hotshot who think they're V6 can handle a true G92 MK6 car, drop me a pm. I'm out. Too many hata's in here.
:lala:
Haters
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
