a nother cam setup ?
Old Mar 15, 2002 | 08:37 AM
claycityman's Avatar
i got a 68 camaro that has a 305tpi 700r4 in it, and a set of summit hedders and 23" glass pacs, stock chip and computer and no smog. what i want to do is to get that muscle car rumble when im setting at the red light or when it is at idle. i got poly motor mounts and what to feel the motor shake like my dads truck. the map senser limits me right? any help is good help and thanks for it all the biggests is what i want http://www.geocities.com/claycitydude/68
Old Mar 16, 2002 | 09:47 AM
help
Old Mar 17, 2002 | 01:30 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
Yes, if you have a map sensor, it senses the manifold pressure and changing cams to achieve the lopey idle you want will also require a PROM change for the computer.
Old Mar 17, 2002 | 01:33 PM
u r sofa king we tah did's Avatar
if you are looking for a choppy idle, just order a cam with LSA of 110, your gonna need to reprogram the computer for the cam, and dont expect it to make optimal power with TPI and a LSA of 110, but it will have that muscle car chop
Old Mar 17, 2002 | 04:41 PM
do i reprogram the comuter or buy a chip and what chip do i need or how do i reprogram the computer what is LSA
Old Mar 17, 2002 | 05:03 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I'm by far no cam genius, but I have to question that statement. Do you remember the Super Profile L98 cam from TPIS. The one that was around 490-510 lift with about a 207-212 duration. It had a 108 LSA and from what I had read, it ran like a bat out of hell on a stock engine. That of course means no prom changes. However, I am curious as how much it loped.
Old Mar 17, 2002 | 11:52 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
LSA is lobe separation angle basically it's one factor that determines the overlap between the intake and exhaust. A lower separation is a greater overlap which is essentially what gives you that lopey idle.
I could be wrong but I'd say any cam change, especially going with say a 108 LSA would really require chip work. In which case I cant stress enough the need to burn your own chips. Go to the DIY-PROM board and start reading up and check out the prom burning intro article https://www.thirdgen.org/newdesign/tech/promintro.shtml
By the way nice little project you got there, good luck with the rust I know exactly where your coming from. Got a 69 Firebird convertible in a bit rougher shape, but it's all there. Would have given up on it long ago if it wasn't a convertible
Old Mar 18, 2002 | 01:28 AM
i dont see how any cam with a LSA of 108 could run on the stock chip. that would have to throw the computer for a loop. maybe that was intake centerline or something.
Old Mar 18, 2002 | 03:21 AM
why cant this be easy thanks for the help when does the cam mess with the map at low rpm or high
Old Mar 18, 2002 | 05:36 AM
Ions91Z28's Avatar
The LSA on it was 108. I even posted a thread about solely it and willie (supercharged 305 camaro) said he knew someone or wondered why TPIS cams made cars run so fast for what they were. I'm not saying running on 108 LSA on the stock chip is perfected, just saying I believe it's possible.
Old Apr 12, 2002 | 09:29 AM
im back
ok im to the point where i want to order a cam which one is it guys. the muscle car sound and lopyyness is what i want. it has hedders now. http://www.geocities.com/claycitydude/68 here it is if you want to look
Old Apr 12, 2002 | 03:06 PM
Bort62's Avatar
Those arent headers...
Street Lethal
Apr 30, 2019 12:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
