Need 3 wire heated O2
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Just wondering is there a certain part number or car I should get one for. The car will have Hooker long tubes so I should go ahead and get one.
Chris
Chris
Some people have recommended :
AC DELCO AFS74 1995 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = Z
I just got one from Rock Auto Parts (do a web search for prices) but I haven't installed it yet.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Originally posted by u r sofa king we tah did
or a o2 sensor from a 1990 ZR1 corvette is a 3 wire
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
25176708 is the PN for the LT5 Vette, it also fits 93 GM W bodies.
AC-Delco # AFS74 is half the price, though. The GM long# is 25312179. This is used in 94-95 GM Light Trucks.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Hey everyone. I got the O2 today and it has 3 wires and a plug. One purple and two brown. I know that the purple goes to the )2 wire, but does it matter which of the brown wires is negeative or ignition. did yall get a plug that will fit into the plug they give you or just cut the wires?
Chris
:hail: TPI
Chris
:hail: TPI
Car: I
Engine: Taunt
Transmission: Mustangs
When I wired mine I soildered in a hot lead from the fuel pump relay, its in a convient location for this and can hadle the extra load. I used a two wire water proof connector with a waterproof fuse case on the hot side. These were both got at radio shack for a couple of bucks. And no, it doesn't matter which lead you use for hot, GM's normally pretty good about that stuff.
:lala:
:lala:
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
So, what are the benefits of running one of these sensors as opposed to factory? I have heard some discussions about em, but Im still not very clear. Thanks guys!
kyle5647
Aug 15, 2015 11:56 PM
