Gas Smell
Old Mar 21, 2002 | 08:57 PM
88greyiroc's Avatar
Gas Smell
I own a 1988 iroc z 350 tpi i just had ford 19lbs injectors installed because the mechanic at the gm garage said that my fuel injectors were stuck open well when this was all being done i had a new oxygen sensor installed also well the car still smells like gas not as bad but it is still there what else could it be???????
Old Mar 21, 2002 | 09:33 PM
Bort62's Avatar
about 3000 Things, Be a little more specific...
If anything I wouldf think your stock L98 prom would expect 22lb injectors, the 19's would end up running you lean.
Old Mar 22, 2002 | 04:46 PM
88greyiroc's Avatar
the car smelled like gas bad and the mechanic said my fuels injectors 1 or many he couldn't tell was stuck open so i had new fuel injectors installed in my car 19lbs fords and new sensor the smell like raw fuel is still there not as bad but its there and i cannot for the life of me figure out how those injectors could possibly make myc ar run rich i figured it would be a bit lean. No codes or anything comes up so i don't know what it is.
Old Mar 23, 2002 | 09:24 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
THE SMELL WAS SO BAD ON MY WIFE'S 90 IROC I THOUGH I HAD RAW FUEL LEAKING OUT THE RAIL. I TRACED IT TO THE CHARCOL CANISTER. I ADDED CLIPS TO THE HOSES ON THE CANISTER AND THE SMELL HAS NEVER RETURNED. I USED THE CLIPS FROM FUEL FILTER HOSES ON A CARBERATORED ENGINE. JUST ANOTHER PLACE FOR YOU TO LOOK.
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
