cam questions???
Old Mar 24, 2002 | 06:46 PM
Don_89Iroc's Avatar
cam questions???
what all needs to be done to a motor if i want to put a mild cam in it????
Old Mar 25, 2002 | 11:51 AM
tpi_roc's Avatar
A mild cam usually means that your lift wont be raised beyond the point of needing new springs
however if its an old worn engine you're due for springs anyways
basically you just change the cam and lifters (if flat tappets) or you reuse the rollers. And possibly springs
you'll need to replace a few gaskets to
water pump, valve covers, intake manifold, timing cover, and possibly pan gasket if you really tweak it.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
