LT4 cam (not LT4 HOT)
Old Mar 25, 2002 | 02:10 PM
camaro6spd's Avatar
It is in between the LT1 and ZZ4 cam....would it be good for a 305 with
1) Hooker Supercomp Headers/Y-pipe
2) DynoMax 3" Cat-back
3) Stock TPI intake ported to the Max, untill I can get SLP runners.
4) Ported Stock Heads
Eventually aftermarket igntion, and possibly heads(next yr)
It won't over/under cam it will it? Whould the ZZ4 cam be better.
Old Mar 26, 2002 | 08:41 AM
Beefy89's Avatar
LT1-.447/.459 lift 205/207 duration at .05 117 LSA
LT4-.476/.479 lift 203/210 duration at .05 115 LSA
Old Mar 26, 2002 | 09:42 AM
camaro6spd's Avatar
thanks, OK so are you stating that the LT1 and LT4 cams are almost the same? I dunno.
Old Mar 26, 2002 | 10:52 AM
Beefy89's Avatar
No,I was showing the specs on those two cams.
I believe the ZZ4 cam is 474/510 lift 208/221 duration @.05 112 LSA. Some people say they are almost the same.
Old Mar 26, 2002 | 04:56 PM
camaro6spd's Avatar
Is anyone running any one of these cams in their 305????????????????????
Old Mar 26, 2002 | 05:23 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I have no personal experience w/ the ZZ4 cam in a 305, BUT people have told me it works great.
I haven't heard of anyone running a LT1/LT4 cam in a 305.
Old Mar 26, 2002 | 06:40 PM
camaro6spd's Avatar
but what did they run the zz4 with...
Old Mar 26, 2002 | 07:57 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The ZZ4 is a better choice. You're going to do a lot of work and swap valve springs anyway, might as well do it once and do it right. The LT1/4 cam would be OK as a bargain basement stop gap effort in a peanut cam car. Definitely not worth it in an L98 cammed car even for free.
Old Mar 27, 2002 | 08:32 AM
Beefy89's Avatar
My L98 runs much better with the LT1 cam.I'm sure it doesn't run low 13s, but I'll run anyone with a stock L98.
Old Mar 27, 2002 | 10:18 AM
camaro6spd's Avatar
OK so the ZZ4 is not gonna over cam that engine....ok thanks....what kind of power do u think it will put out?
Old Mar 28, 2002 | 05:18 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I'm not very good at guessing these thing but, I'll go w/ a solid 20hp. This also depends on what else you have done to the car.
Old Mar 28, 2002 | 06:37 PM
bigals87z28's Avatar
Car: Check The Sig
camaro6spd, thanks for posting this thread... i have a 305 and im just reading everything... i just wana know if i put a zz4, what will i have to change... springs, lifters, rods and valves? rockers? and will the zz4 cam keep my car emisions legal? hey its NJ! i wana change the cam i was thinkin of gettin a cam out of a manual and get a different converter...
f-bodyz28
Sep 2, 2015 05:03 PM
masonta
Sep 1, 2015 06:40 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
