What should my oil pressure be in idle?
Old Mar 30, 2002 | 01:29 PM
Mohammed's Avatar
Car: 88 IROC-Z
Transmission: 700-R4
Old Mar 30, 2002 | 02:31 PM
rhuarc30's Avatar
Around 30 psi hot.
Old Mar 30, 2002 | 02:48 PM
Mohammed's Avatar
Car: 88 IROC-Z
in my car it 50 to 60 psi, what's going on
Old Mar 30, 2002 | 07:22 PM
rezinn's Avatar
If your oil pressure doesn't behave as you think it should you can always replace the oil sender behind your intake manifold. Your pressure should be high when cold and gradually come down a bit, and raise with rpms. 10 psi per 1000rpm is safe, but when hot the lowest my pressure falls is about 20psi. The thickness and type of oil could have something to do with it as well.
Old Mar 31, 2002 | 11:23 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Im at about 40 at idle, when hot, with Mobil 1 10w30.
Old Apr 5, 2002 | 04:39 PM
BLUEIROC5.7's Avatar
mine is about 15 at idle. I just used mobil 1 10w 30.I just replaced the oil presture sender. My was on top of the oil filter. Do i still have a problem.
Old Apr 5, 2002 | 04:40 PM
90Form350's Avatar
no, my oil pressure is 20 hot, on a mechanical gauge, with 2500 miles on a new motor with 10w30. its normal.
Old Apr 5, 2002 | 04:43 PM
thanks . IS 20 the first line
Old Apr 5, 2002 | 04:58 PM
sIcK pUpPy's Avatar
15 PSI is normal at idle for these cars when they are at operating temp, that's were i'm at. Under load, it's around 40ish.
JD
Old Apr 5, 2002 | 07:07 PM
Old Apr 5, 2002 | 09:14 PM
Hey all i just replaced my sending unit. and drove around for a while and the gauge droped to just above the red line again. What else can i do. Please help
Old Apr 9, 2002 | 10:23 AM
sIcK pUpPy's Avatar
Sounds like it's time for a new oil pump. How many miles are on the ol' girl?
Old Apr 9, 2002 | 10:26 AM
The block was rebuilt and has 27k on it. I wnt for a drive and the gauge was fine. I think the gauge is massed up. what do u think
Old Apr 9, 2002 | 11:03 AM
sIcK pUpPy's Avatar
Install a manual test guage (pick one up from your local auto parts store), it's the only way to tell for sure. I'm not certain where to install the guage, I assume that you would pull out the sending unit and test it there. But find out for sure.
JD
Old Apr 9, 2002 | 02:30 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
i think the oil presure gauge is screwed up.... it is always sitting up at around 60 psi ( top of gauge ) it doesnt move much either. im very confident that the engine is running fine, i would just like to all of the gauges functioning properly.
Old Apr 9, 2002 | 02:31 PM
My oil pressure
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
