ZZ4 owners, whats this plug in oil passage??
Old Apr 2, 2002 | 03:04 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I found this on the Scoggin-Dickey page about an oil passage plug above the rear main that should be installed, its about half way down this page:
http://www.sdpc2000.com/htm/techtip....Torque%20Specs
It says on "Bare Blocks" it is not installed from the factory, what about short blocks/rotating assemblies?
I did not install one on my ZZ4 short block/rotating assembly, did anyone else?
My oil pressure seems low compared to all of my previous motors, its 12-15# at idle.
I asked SDPC tech line, but did not get a real competent sounding answer. Hate to pull it apart again..
Old Apr 3, 2002 | 03:01 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yike,s I have the ZZ4 crate motor, and I have good oil pressure (almost 30psi at idle). Almost sounds like something wasn't done on your motor.
Old Apr 3, 2002 | 05:33 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I'm guessing you got a bare block and ZZ4 rotating assembly separately and then assembled it yourself? Because my ZZ3 shortblock's oil pressure is at 30 psi at idle fully warmed up, so I'm assuming this plug is installed on mine from GM (I would hope so!) It's probably safe to say then this plug is in all their shortblocks.
If you didn't install the plug you're basically bypassing the oil filter and circulating unfiltered oil through your block. I know it's a PITA but I'd tear it apart and install the plug.
Old Apr 3, 2002 | 09:27 PM
2QUIK6's Avatar
Actually, no, the rotating assembly was installed, it was really a shortblock with the cam removed.
The thing is I have real good oil pressure until it gets hot and has a few higher revs on it, then it drops like a rock.
The guy at SD said he's seen several ZZ4/ZZ3's that barely have 10psi at idle
Old Apr 4, 2002 | 11:15 AM
99Hawk120's Avatar
Yeah, that ain't right. I've got a '79 vette with a 350 that's on its last legs and it can usually muster 20psi at warm idle (never goes above 30 though).
Old Apr 8, 2002 | 10:12 AM
2QUIK6's Avatar
Well I popped the oil off again, and the plug was already installed so that ain't the reason for the low oil pressure. Guess its just the sloppiness at GM Mexico that built the ZZ4....won't be buying another block from GM again. What gets me is at cold startup before everything expands I'm getting 65+# of oil pressure then when it gets hot its about 15-20# with a brand new HV/HP oil pump!??
Everything is brand new in this motor, I've inspected all the main journals and rod journals and all seem ok, a couple were discolored to a gold tint but were still smooth.
Old Apr 8, 2002 | 10:29 AM
99Hawk120's Avatar
Hmm.
The discolored tint seems indicative to me of residue from overheated oil. How hot does your motor get?
Here's another question, when was your ZZ4 motor built? Mine's more than 3 years old now.
Old Apr 8, 2002 | 05:47 PM
2QUIK6's Avatar
Originally posted by 99Hawk120
Hmm.
It runs at about 200 degrees F, never over that.
I received the ZZ4 block and rotating in July from Scoggin-Dickey last year and installed it in Oct. last year.
Only 2 main journals, #3 &4 had the gold discoloration, all others and rod journals were gray with little scratching.
Old Apr 9, 2002 | 10:29 AM
99Hawk120's Avatar
I would check the bearing clearance on those two bearings.
eightsixseven
Dec 16, 2024 01:50 PM
lt500r55
Sep 1, 2021 01:30 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
