Holley Stealth Ram
Old Apr 3, 2002 | 11:45 AM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
Holley Stealth Ram
Has anyone completed a Stealth ram install on a 3rd gen Camaro? With no EGR valve provision will you pass an emissions test? Will you set any codes? I'm looking to buy one. Have ported plenum, Accell long tube runners and ported base for sale.
Old Apr 3, 2002 | 01:39 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Well, noones completed the install yet, because it is so new. People here have gotten it though... You can order it from Summit as a special order item. I plan on using it on my 406... cant wait!
How much do ya want for the Accell runners?
Old Apr 3, 2002 | 02:27 PM
ostrich's Avatar
Car: 85 Iroc-Z
I've seen the price etc at Summit. I have a 383 TPI in an 85 Camaro. Turned 310hp, 420lb/ft on a DynoJet chassis dyno. Looking for more. Either a Stealth Ram or Accell super ram. I wanted to sell the runners etc all together. I will separate if I have to though.
Old Apr 3, 2002 | 03:31 PM
GoFast91Z28's Avatar
I ordered mine on 4-1. Summit said they are about 4 weeks wait right now. As for the numbers.... ( these are mostly rumors based on facts and holley techline ) I hear that the intake should flow near 300 cfm per runner and there should be enough material to do a gasket match to a Fel-Pro 1206 intake gasket. I hope those rumors are right. As soon as mine comes in I'll post what I can as far as runner size and exactly what's included w/ the fuel rail accessory kit but I won't be able to install it until the later part of May. I hope this intake turns out as promising as it looks:rockon:
Old Apr 3, 2002 | 03:38 PM
ostrich's Avatar
Car: 85 Iroc-Z
What are you installing it on? What are you going to do about the EGR valve?
Old Apr 3, 2002 | 03:50 PM
Well, here in good ol' Illinois, we don't ever get checked for emmisions what so ever. If it runs and has all the proper lights and a license plate- no one will ever question anything. I am kicking around drilling a set of vortec cyl. heads to the old bolt pattern and doing a gasket match on the intake. If I get the intake and it looks like that isn't an option then I will probably put it on the stock L98 heads for now.
Old Apr 3, 2002 | 05:39 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
how much is the stealth ram setup?
Old Apr 3, 2002 | 07:20 PM
90Form350's Avatar
i've heard about $450
Old Apr 3, 2002 | 09:30 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
does anyone have a link to where you can buy one?
Old Apr 4, 2002 | 07:05 AM
ostrich's Avatar
Car: 85 Iroc-Z
You can get one at Summit www.summitracing.com. Holley part #7540 or 7540p (p=polished). Ive heard you will probably need the fuel rail kit as well. Don't have a part # for that.
Old Apr 7, 2002 | 06:10 PM
Gruvin84SS's Avatar
hey ostrich,
You have mail and PM on your old intake stuff. looking to get whole setup. let me know.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
