I need help fast!
Old Apr 4, 2002 | 04:56 PM
JT 85 TA 305's Avatar
I need help fast!
I started my car(a 85' TA 305 TPI) up one morning and it had a crappy Idle to it. On the street, it jerked forward and back wildly and at stops it almost stalled out. Then after driving for a minute or two the car spit out a code 44. I went home and was already going to replace the plugs so I did and checked the wires. It still ran the same so I changed the fuel filter, cleaned out the IAC, adjusted the TPS to 0.550 volts, and replaced the O2 sensor with a bosch. Took it out and still ran like crap and spit out a code 44. I love my car and so do the ladies so someone please give me whatever help or suggestions you can. thanks
Old Apr 4, 2002 | 05:00 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Pull the line to the MAF and see if it improves. If no help, verify the cable to the O2 sensor is OK.
Here a scan tool would show what the ECM is seeing.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
