under drive pullies
Old Apr 10, 2002 | 10:57 PM
chevy power's Avatar
under drive pullies
just wondering about "under drive" pullies, how much will these hlep, who makes the best ones for 3rd gen application. also how much $$$ are they, and can i install them myself?
Old Apr 10, 2002 | 11:11 PM
chiefz28's Avatar
I'd say if you hae any kind of mechianicial skills at all you should be able to install them.Once you have them installed you'll nee a shorter belt.I just routed a piece of string around the pulley the same way as the belt goes and marked it and took it to the parts store and had it matched.Summit and jegs carry March Underdrives for about $170 or so.
Old Apr 11, 2002 | 12:42 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Check around some of the underdrive kits come with a new belt to save the hassle finding a shorter belt.
Old Apr 11, 2002 | 01:12 AM
Kandied91z's Avatar
unless your strictly at the track i would look elsewhere for improvements.....very few have had really great things to say about them.
just to give you a different point of view to think about.
Old Apr 11, 2002 | 03:51 AM
Jza's Avatar
Jza
Don't waste your money if you drive the car on the street frequently.
Old Apr 11, 2002 | 03:55 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Agreed, they aren't worth it. Many also have BS with them after they are installed.
Old Apr 11, 2002 | 05:28 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
not worth the trouble
unless you are reving the motor into the 6-9k rpm range you are not going to gain much
maybe 1-4 hp
and that is a big maybe
even on my wankle which I spin to 7600-7800 rpms before i shift when racing would not do that much different with them
Old Apr 11, 2002 | 08:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
i installed the march 3 pc billet set on my last 91z28 and went through 5 altenators in a month. it was a 350tpi with auto. pulleys are not what people hyped them up to be. 15hp my ***. maybe 5. you will almost always have charging problems. i got mine more for the billet look in my engine. when my silver z28 burnt. i didnt even bother taking them off.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
