Anyone out there with a 305 TPI (LB9)...
Hey
I was just wondering if there was any 305 TPI guys out there that run low 14s. If u guys run low 14s post ur mods please... Post ur times also even if you dont run 14s.... I have a 305 TPI engine and I am planning on getting my car into low 14s or even high 13s. So I am just looking to see what all you people have done to ur 305s and how u did it. If u have any suggestions for mods please post them.
Thanks alot
http://camaroz28.cardomain.com/id/56424
edit. Sorry, no more pics not technically related to the post
Thanks alot
I can't tell you my track times as I have not yet been. I have had the car for over 4yrs but something always gets in the way of me going. I had plans to go this summer but now I am out of the country and won't be able to run it. I will keep my eye on yours and see what you can get at the track. Mods are in sig. 3.42 gears on the way
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The times in my sig were run on a beat *** clutch, and 2 slightly bad injectors... Had good traction due to the terrible clutch! The new Centerforce is in, and will have some new times in a couple weeks... I think I just inherited some new traction problems with this clutch though.
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
not low 14's but 14's
if my posi worked and i had some spohn suspention parts and drag radials i would be in low 14's for sure
look in sig
look in sig
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
14.163 @ 98.16 mph on Pep Boys 245/50 ZR16's.
This time was with Performance Resource shelf chip.Had them burn custom chip & ran almost 1sec SLOWER.They reprogrammed chip hoping to run high 13's w/ it this fri @ Cecil County.
BD3
BTW Ed M. and I are in a dog fight to see who gets to 13's first!
This time was with Performance Resource shelf chip.Had them burn custom chip & ran almost 1sec SLOWER.They reprogrammed chip hoping to run high 13's w/ it this fri @ Cecil County.BD3
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
As you can see I've only gotten the heavy beast into mid 14s. If your IROC is lighter you might get into low 14s with similar mods and your better cam.
Besides these some valve train and head work should get the job done.
Car: Formula
Transmission: M5
14.06@98.8 with street tires and 3625 lbs(including me!)
accell headers
banks 3" catback
gutted cats
1.6 rockers
slp cold air induction w/K&N
slp siamesed runners
ported upper plenum
accell coil-cap-wires
160 deg. stat
ads chip
hurst shifter
centerforce df clutch
stock 3.42 posi
stock heads, cam, and gears
accell headers
banks 3" catback
gutted cats
1.6 rockers
ported upper plenum
160 deg. stat
ads chip
hurst shifter
stock 3.42 posi
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
should be 13's i haven't ran with the ported heads, lt1 cam, 4inch siamesed intake, AFPR
also these are done on street tires, on stock prom, 115,000 miles and at 1200 ft elevation
Andrew
Andrew
Hey
what do you guys think I will run with SLP or Hooker headers, cat back exhaust and a transgo shift kit. All my info is in my sign.
Car: 1991 Z28
Transmission: WCT-5
I run 14.8 on my stock 305. I have a 91Z so I have the advantage of the speed density sytem... I recomend you do the conversion if possible. I ran 14.8 with a 2.73 gear posi, K&N's with a guted air box and some dryer ducting to get the cold air up in there, and a hooker 3" cat back exhaust system. Im hoping to get in the mid to low 14's by the end of the summer. I have a set of hedman shorty headers and a 3.42 gear disk brake rear from a 4thgen sitting in my garage waitign to be bolted on. That with some lenum porting Im hoping to see 14 flat.
I went 14.5's @ 95mph with LT headers, Cai, ported plenum, siamesed base, a 210/216 .440/.454 comp cam, stock stall, an open 3.23 rear/ and a crappy tranny.
I decided to go fast so i pulled it all out for my 406
iroc_cragg, I run the mixed 1 1/2" & 1 5/8" Edelbrock TES, ceramic coated in/out. This is quite enough for a NOA LB9; Lingenfelter even puts 1 5/8" on his L98 buildups though I would go with 1 3/4" on a L98.
BTW, the TES allow std length spark plugs and MSD wires with no burn problems; plugs are easier to change than with stock manifolds.
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
