Accident on the strip
Old Apr 15, 2002 | 12:04 AM
86305's Avatar
Man saturday night me and 2 of my friends who drive stangs went to the local track. Well i wanted to drive my buddys 93 gt just to see what it had. Well at about 80 something locked up in the rear. Car cut hard right into the wall and rolled onto the drivers side door. I got lucky and just got bruised a little and i have 2 stiches over my eye. But now were worried about the car. What could have happend. I'm not very good when it comes to rear ends and trannys so i'm confused.
Does anyone have an idea what would make it lock up and jerk to the right like that.
Old Apr 15, 2002 | 11:54 PM
86305's Avatar
Come on guys were trying to figure it out. With the reear end off the ground the back tires won't spin. Is there any way i can figure out what exactly is locked up.
Old Apr 16, 2002 | 12:05 AM
EvilCartman's Avatar
Car: '82 Z28
Unbolt the driveshaft and see if the rear wheels will spin. If they do, it's gotta be something with either the transmission or the engine itself. If they don't spin, then take a look at the rear end.
Old Apr 16, 2002 | 01:47 AM
87RS402's Avatar
A spider gear explosion would do that. I had that happen to me in a 4X4 truck once. Luckily the axles snapped so I was able to roll on all 4 tires to a stop on the side of the road.
Old Apr 16, 2002 | 08:35 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thats probably what happend. I know the spider gears on "non posi" fNord rear ends are crap and if the roll pin or clips break or come loose the rear end will lock. It happend to my Mom in her old bronco. Funny though 99% of the time with a GM rear breaking the same way you wont lockup just roll.
SSC
Old Apr 16, 2002 | 08:40 AM
86305's Avatar
well the drive shaft is out and the tires don't spin. I geuss a new rear end is on the list of things to replace. THe universals are almost broke and the weld on the the end of the drive shaft is craked. Do u guys think it damaged the tranny.
Old Apr 16, 2002 | 03:34 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
ummmmmmmm is this an info board for guys that drive stangs? huh i had no idea
Old Apr 16, 2002 | 09:28 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
If there is no visible damage to the tranny it should be ok.
Old Apr 17, 2002 | 01:00 AM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Same thing happened to my friends 74 Vette. Only difference is, it happens to his when he is stopped. The rear end would lock up and not allow the car to move at all, even if it was in neutral. They opened the rear and it was fine... changed the u joints and just about everything else under there. They have no idea what it was... it hasnt done it in a long time though.
Who knows, it could be the same thing as my friends Vette, but as I said, we have no idea what the problem actually was. Mystery to everyone that has heard the story.... thank *** it didnt happen to him while he was driving.... and your lucky that you are ok.
Old Apr 17, 2002 | 05:02 AM
ronterry's Avatar
Car: '94 Corvette
Are you sure one of the brake pistons on the Vette didn't jam up in the cylinder.
I only say this cause I know Vette guys, and they don't put a whole lot of miles on there cars. They sit a lottttt. Those little flying gremlins start to bread over the winter - you know.
I think I put a whole 5000 miles on mine last year.
Ron
Old Apr 17, 2002 | 12:53 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Wow that sux. Was he pissed? Got any pix? can you get any pix of the broken spider gears?
Old Apr 17, 2002 | 10:04 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
ronterry... that is quite possible. It has not happened in over a year, but I will mention that to him as a possibility. That actually happens to my fathers Cobra.
Old Apr 18, 2002 | 02:29 PM
bradkeith's Avatar
86305, I'd be willing to bet that the cross-pin backed out of it's hole and jammed the carrier. I dunno what rear the 93gt has in it, but the ford 8.8's were notorious for doing that.
Old Apr 18, 2002 | 03:05 PM
SDTADave's Avatar
The pin or bolt that holds spiders in place could have broken letting the spider shaft to fall out, locking the rear end up. Same thing happened to my brothers CHEVELLE, he didn't flip or anything but the guy at the local chev dealer parts counter said that the little bolt has killed alot of people. Now hows the friend holding up to having his car flipped?
Dave
Old Apr 19, 2002 | 02:37 PM
Dave
Now thats what I want to know.
Old Apr 19, 2002 | 03:35 PM
Jay 727's Avatar
Not to be a smart *** but to answer a dumb question I'd say get out the tool box, do you own any hand tools at all?
Come on, take stuff apart, sooner or later you'll see a problem. I'm guessing it's not going to be a grain of sand stuck between the ring and pinion gears. If it locked up that bad it should be quite obvious when you take it apart and find the problem.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Amillionoh7
Sep 5, 2015 11:44 PM
