(T56 swap) Dakota Digital Users?
Transmission: A4
i just installed mine and i am also using 3.73 gears but i have not got to run it on the street yet. im still putting fiishing touches on new motor. i will let you know what my settings are set at tomorrow or something. it can give you a good starting point.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Brian Shaughnessy, how well does your speedo work in your car with the dakota box, any problems with it like a bouncing speedo needle or stuff like that?
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Sumtimes it bounces while idling.... like up to 80 or so... why ???
I suppose I should run a real shielded twisted pair from the speed sensor up to the dakota box... but I'm either A. lazy or B. too f'ing BZ at the shop working on my Charger or the GTA's rear end right now.
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
SGI-5
Using the SGI-5, no bouncing needle at all. As for the setting it's best to get another car with you and compare speeds, then do the math as suggest in the instruction and then you will have the correct settings, no matter what rear end gear you are using.....
HTH
HTH
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
