T-5 Limits
T-5 Limits
I understand that my T-5 Transmission is has some major limits, it's in a 1990 IROC. I just replaced any parts in it that looked worn, or chipped so it should be good as new. How much horsepower and torque cxan it take before I have to rebuild it again?
There rated at I think at like 295 lbft's. They are not kidding just to let you know. It is a weak trans. You I think have a worldclass if you have a 1990. This was a bit stronger trans and it should be ok if you haven't modded it too much. I'd say you have some time..alot of time itf you don't beat on it.
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
see sig, i had a t-5 and ran those times. it did break though, it had 100000 miles and i beat it hard. no power shifts though!
and your problem is? make up data? I read a manual on the T-5 which states that the older T-5 handles up to 310ft-lbs, and the world class to 350, im sorry about the 375 i checked again. somewhere in my house is an old car craft i believe which states that the w/c T-5 handles about 350ft-lbs. listen guy...i write what i read, i didnt design the trans. so you can cut the "angry" bit. this forums meant for information purposes. i have a T-5 in my 383. and it hasnt blown yet
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Everything I have seen says the regular T5 is rated at 290 ft/lbs and the world class T5 is 310 ft/lbs. My son's car (Kevin91Z) dynoed at over 400 ft/lbs of torque at the rear wheels. He just recently went 12.80 @ 108.50 MPH. But the very next time at the track he broke third gear. Now we have the T56 in it.
I'm keeping my T5 until I get my vortec-head engine in, then I am going with the aftermarket T56.
I checked the manual very closely to get a good understanding, it doesnt specify but i think the its the ford T-5 with the 350ftlbs torque rating. this would make sense since since i just heard that the ford w/c T-5 is the highest rated.
My curiosity has got the best of me now...if the fords t-5 is really stronger, could the bell housing and the extension housing be changed from a GM to the ford and be swapped to a 350? would the splines mesh correctly? that could be worth some thought.
ive got a late model ford T-5 in my 67 mustang, its just sitting there, i could put it to some good use.
