3.27 Borg Warner Gear Lube
Old May 8, 2002 | 05:29 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Looking for a good synthetic lube for the final drive, any ideas?
Don
Old May 8, 2002 | 07:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I use Royal Purple w/ no probs, there's many out there. Make sure it has the slip juice in there, or buy a seperate bottle to add in so the clutches don't chatter.
Royal Purple can be had from Jegs.
Old May 8, 2002 | 10:07 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I personally use valvoline 80w90 with the additive in my 9 bolt.
Miles
www.9bolt.com
Old May 9, 2002 | 08:18 AM
85 T/A WS6's Avatar
Thanks, I read on the tech article here that if you use synthetic, the additive is not needed
Don
Old May 9, 2002 | 09:31 AM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
I use 75W90 with additive
Can't hurt
Old May 9, 2002 | 08:54 PM
Eightyninef's Avatar
there are no clutches in the 9bolt to chatter. I'm running pennzoil limited slip GL5 lube and it seems to be working OK. no extra additive.
Old May 10, 2002 | 06:16 AM
KeithO's Avatar
You may find these interesting:
https://www.thirdgen.org/techbb2/sho...threadid=72062
this:
https://www.thirdgen.org/techbb2/sho...threadid=77011
and this:
https://www.thirdgen.org/techbb2/sho...light=additive
Old May 10, 2002 | 06:57 AM
JoelOl75's Avatar
Wow, I didn't realize the can of worms about the slip additive. I guess it's an option between hard lockup and increased wear, or weak lock and extended life?
The tradeoff's to be made
Old May 10, 2002 | 07:41 AM
87ROCZ's Avatar
My 2 cents worth
Add the additive? YES ? NO? It's a heated debate... but here is my story...
Last week I tried a burnout in my car... 3.27 BW posi 9-bolt... I pulled a peg-leg....
I pulled the inspection cover and changed the rear fluid with some 75W90 Synthetic Gear Lube and added a bottle of GM Posi additive.... I will add here that the gear lube in my rear was seriously in need of a changing (although it was changed at some point because there was a silicone gasket) it was black and a little gritty.
All changed up I take my car out.... definitely feels like she is pulling better. Got to a stop sign yesterday, reved it up to 1000 rpm, let the brake go and jammed it.... two nice black stripes and a little sideways action..
Did the additive make a difference? Maybe, maybe not but I know my posi rear is working a whole lot better now!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
carattini
Sep 10, 2015 07:46 AM
Randomtask2
Sep 7, 2015 05:06 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
