Five or six speed?
Old May 17, 2002 | 08:03 PM
cybertiger130's Avatar
Car: Trans-am
Five or six speed?
How can I tell if the trans is a five or six speed ? The trans is a 4L60E automatic transmission
Thanks Mike.
Old May 17, 2002 | 08:22 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
its a four speed auto. five and six speeds are manuals (t-5/t-56)
Old May 17, 2002 | 08:28 PM
kevinc's Avatar
Car: 1982 Z28
Re: Five or six speed?
Thanks Mike.
Ya know how, when you're accelerating, the tach drops suddenly but the car keeps gaining speed?? That's the trans changing gears. Start from a dead stop, accelerate to a safe highway cruising speed, and count how many times the tach drops...that's how many gears your trans has.
Treat your brain like it's a muscle, not a finite resource. You can use it all you want and you'll never run out.
Old May 17, 2002 | 08:40 PM
Car: 88 Camaro SC
Engine: SFI'd 350
its a four speed. My olds cierra was the only car that i owned that had a trans that had gears differing from the numbering on the dash (the prev. owner put a four speed in). To the left of "D" was overdrive, to the right was drive. Really f'd with people i loaned the car to... they could never figure how to get it into drive
Old May 19, 2002 | 01:34 PM
streetrunner's Avatar
so how many speeds does the 4L80E have?
i thought they had 5 speed auto in the LS1 Z28's
Old May 19, 2002 | 05:06 PM
Car: 88 Camaro SC
Engine: SFI'd 350
thats a four speed also but its alot stronger than the 4l60-E. Rated for engines with up to 440 ft-lbs of torque. I think the 4l60-e is just 350 ft-lbs.
Old May 20, 2002 | 04:59 PM
Little GTA's Avatar
Sometimes people think the lock up converter is another gear.
Old May 29, 2002 | 11:40 AM
y hasnt anyone built and installed 5 or 6 speed manuals in stock cars from the factory? would they juss simply be too big and too heavy? It just seems to me that the more gears you have the more acceleration and economy u can have with the OD gears and stuff.
Old May 29, 2002 | 11:49 AM
Little GTA's Avatar
They have
Old Jun 3, 2002 | 12:30 PM
which tranny is called the "allison"? isnt that one a 5-speed Auto? or is it the 4l80e?
Old Jun 3, 2002 | 01:41 PM
87RS402's Avatar
Allison is a transmission manufacturer, they build transmissions for semi trucks, buses, tanks.... All heavy duty transmissions. Those com in anywhere from 3 speeds up to 9 or 10 speeds IIRC.
Old Jun 3, 2002 | 01:54 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
GM put the 4L80E in 92 & up 3/4 & 1 ton trucks with gas engines & all light duty trucks with 6.5L diesel engines. In 2001 GM debuted the new Duramax diesel. It comes with a special Allision built 5 speed auto trans.
Old Jun 4, 2002 | 01:48 PM
Ergo60's Avatar
6 Speed Auto
I believe that Jett makes a 6 speed trans. I believe that they use the 4L60 or the 4L60E and stuff a few new gears between the ones already there. Check out their site.
Old Jun 4, 2002 | 07:07 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Re: Five or six speed?
He might not have had the trans installed when he asked the question.
Brian
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
Giocio
Oct 1, 2015 12:20 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
