Is a 4 pass 10,000 gvw cooler big enough for my car?
Old May 27, 2002 | 09:44 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I have one sitting around, and thought I might install it while IM swapping the new tranny in. I think the brand is Flexolite, Just not sure if its big enough to make a difference in the temp. Should I install it?
Thanks,
Mike
Old May 27, 2002 | 10:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you're installing a higher than stock stall converter then you should have an external cooler.
Without a tranny temp gauge it's hard to say if the cooler is big enough or not. You want to keep the tranny oil in the 175-225F range.
Old May 28, 2002 | 01:04 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Reference my response to your other post....
As to the size, I always use the 24,000 GVW cooler, unless it won't fit my application...but you should be able to fit it on your car.
Why? Because it is more efficient and provides better cooling.
onefreakz
May 14, 2018 12:15 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
wruiz
Aug 11, 2015 02:59 PM
