28 Spline Axle Conversion...
Car: 86 TransAm
Engine: 360 SBC 4Bolt / Bowtie Heads
Transmission: T5 NWC Manual
Axle/Gears: Torsen T2 / 3.23
Hi Guys,
I want to install a new posi into my '86 TransAm. Because I want to go to series 3 late model carrier I will need to install 28 spline axles in place of my 26 spline axles. Do these fit as a straight replacement or is there some difference in diameter, length etc? If anyone out there has done this and can help, it would be appreciated... Thanks...Regards...
86trNZam.
86trNZam.
Car: 86 TransAm
Thanks EDE... That's what I was hoping to hear... kind regards...
86trNZam.
86trNZam.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you buy the posi for 28 spline then you'll need 28 spline axles. 90-92 28 spline axles are a direct replacement for the earlier 26 spline as long as you have the proper carrier.
Better 28 spline axles are only $125 each from www.tomsdifferentials.com
Car: 86 TransAm
Cheers Stephen,
Thanks for the link, will check it out...Regards...
86trNZam
86trNZam
86trNZam, Just go to an auto salvage yard and have 'em pull you a set. Make sure the bearing surfaces are smooth when they pull'em. Normally they price 'em accordingly to that. ($50-$100). Scan the yards and find the lowest mileage 90-92 out there . Good luck
Sorry, Just realized you are overseas? Yea, better go new if there isn't much to pick from over there. You might get a U.S. salvage yard to ship ya some ,but it would be risky not being able to see'em first.
Car: 85 IROCZ
Engine: 305ci
what else carries the camaro axle. i was once told that the 90-92 s10 axles would also work? i can find more s10 in the yard, hard to find c&f's.
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
So if I have a 26 spline axle rear now, I can buy 28 spline axles and a 28 spline Posi and this will bolt in as long as the series carrier matches the gears?
Just need to make sure the axles are the correct length. Thread
Prodigious
Sep 18, 2015 05:23 AM
rudolphschenker
Sep 4, 2015 02:41 AM
