Transgo Advantage
Old Jun 1, 2002 | 12:48 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Transgo Advantage
What is the Advantage of having a Transgo Shift kit (Noyoyo-syskokal kit SK700-D), Transgo Reprogramming Kit, and a .500 Vette Servo.
I'm trying to determine if I really need all three parts install in my transmission for a performance street car. If so what will I lose by NOT installing the Reprogramming Kit. My Tranny is a 84 27spline. Also would you recommend that I rebuild the tranny before installing these parts. I have a bout 35, 000 mile on the tranny since it was last rebuilt.
Old Jun 1, 2002 | 11:26 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I beleive most tranny guys would say skip the .500 boost valve and maybe go with a .471 for your setup.
Either way ttt for ya.
TransGo is the best to go with.
Old Jun 2, 2002 | 05:09 AM
transfixleo's Avatar
On an '84 the TransGo Shift Kit (NoYoYo) is essential to correct inherent timing problems as well as friction failures in the 700.
The Reprogramming Kit is essentially a TransGo Shift Kit with added HP/HD features BUT it does NOT have the shift timing corrections of the SK, that is why on those years I combine the two. For a good Small Block the .422" is fine with the TransGo, .471 if you REALLY are making some power.
djmarch
Oct 2, 2015 10:41 PM
italiano67
Sep 22, 2015 08:42 AM
crazynights
Aug 21, 2015 06:53 AM
age
Aftermarket Product Review
Dec 5, 2001 06:20 PM
camaro6spd
Carburetors
Mar 20, 2001 07:49 PM
