A little play in my rear end... (Oh, shut up.)
Old Jun 8, 2002 | 11:35 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
So, while swapping suspension components, I noticed what some (including me) might consider to be a problem.
Seems that I can move my pass. side rear axle about 1/8 to 1/4" up and down- inside the housing... So obviously that bearing is trashed. My question- what is the possibility that the axle itself is OK? I mean, I am taking it in to the the rear completely redone (new diff, new bearings, new seals, 3.73's...) but do you think I'll need to get axles also?
Oh yeah, and from everything I've read, my 90 Formula 350 *should* have 28 spline axles, correct?
Thanks!!!
Old Jun 9, 2002 | 11:38 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I don't know what tolerance those have to be kept at, but I would take a micrometer and measure the bearing surface of the good axle, then measure the bad one and see if they are off. They might be a little but what you would be looking for is ALOT of difference.
Take a look at the "bad" axle, it may be all garbled up so you may not even have to do that much.
Old Jun 10, 2002 | 09:12 AM
a73camaro's Avatar
Best to take apart and visually inspect. There are offset bearings that distribute the load to another part of the axle that is not worn.
Old Jun 10, 2002 | 02:04 PM
82camaro's Avatar
Car: 82 camaro SC
I've been running a pair of the 'repair' bearings for around 6 years without any problems. They are offset so the bearing rides on a different part of the axle. If the axles are at all questionable, get the repair bearings.
customblackbird
Aug 15, 2021 10:16 PM
Fronzizzle
Aug 17, 2015 02:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Fronzizzle
Aug 9, 2015 01:15 PM
