Drive Shaft loose in Tail shaft
Old Jun 17, 2002 | 01:10 PM
alex13507's Avatar
forgive me for not being familiar with transmission terms.. so please bear with me..
got a 88 350/TPI/Auto/700r4/3.27 rear... it is leaking transmission fluid out of the rear of the tranny where the drive shaft comes in (tail shaft?) ... and the drive shaft itself seems to be very loose.. ... as in it can move a few inches around in a circle...
how much play is that suppose to have?
what is holding that into the transmission? it is a slip fit... right?
a guess that we've come up with is the bushing and seal need to be replaced... is this on the right track?
anyone else have this problem before?
on a side note.. the car seems to have some vibrations coming from the rear when in higher rpms... could this be the cause?
any help on this topic would be appreciated... :hail:
Old Jun 17, 2002 | 02:01 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
A worn bushing would not give a few of inches of play. The bushing is only about an 1/8" thick. If this is true, you have other problems.
Old Jun 17, 2002 | 03:16 PM
MX265
Guest
Posts: n/a
I just brought my '89 IROC With 700R4 Tranny to the shop a few days ago for the excat same thing. They told me that the driveshaft yoke, that goes into the tail shaft, was twisted and this sheared off part of the bushing. They are swapping out both the yoke and bushing this week.
Andy
Old Jun 17, 2002 | 08:04 PM
Nordbert's Avatar
Remove the driveshaft and inspect the yoke for wear. If it is worn severly, check for a worn tail housing bushing and/ or a
missing body to engine ground strap.
Old Jun 17, 2002 | 08:58 PM
alex13507's Avatar
Andy
got an estimate on a price? ball park at least?
Old Jun 18, 2002 | 06:31 AM
MX265
Guest
Posts: n/a
I will have a price today. It is being replaced by a Goodyear Gemini Center. They have done great work for me over the past several years and they have been a real huge help in getting my IROC back together. I will post what it cost me later today.
Andy
Old Jun 18, 2002 | 09:46 AM
MX265
Guest
Posts: n/a
I had a lot of work done, but they broke it down for me. The parts and labor for replacing the yoke and bushings and seals between the drivesahft and tranny tailshaft came out to $243.00. You don't want to know what the rest of the bill was. Yikes!!! Hope this helps.
Andy
Old Jun 18, 2002 | 10:54 AM
alex13507's Avatar
Andy
it does in deed... hoping that's all I need!!!
thanks for the info
Old Jun 18, 2002 | 11:17 AM
MX265
Guest
Posts: n/a
No problem. I brought the car in to have some struts, strut mounts, wheel bearings, brake rotors and calipers replaced. I also wanted them to check on the mystery drip in my driveway that appeared overnight. They found the drip was coming from the driveshaft yoke\Tailshaft area. They found the yoke was twisted and warped a little and it tore up the driveshaft bushing in the tailshaft. The bill was a little scary that I just got for all the work that they completed, but for the driveshaft yoke problem that you and I are reffering to, it was right around $243.00. The rest of the bill for the other work was a little bit more than that.
Good luck. BTW, Goodyear Gemeni does great work near where I live. I don't know if you have one in your area, but ya may want to check.
Andy
Old Jul 30, 2002 | 10:04 PM
alex13507's Avatar
sorry for the late response... but i wanted to post that it was the bushing... and all is better...
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Andrew6.688
Dec 13, 2015 10:59 AM
jharrison5
Aug 19, 2015 05:53 PM
