Is the T-56 trans mount the same as a 700R4
Old Jun 28, 2002 | 04:31 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
If my clutch kit gets here next day air like it supposed to, I'll be in the garage all weekend. Just wondering if the mounts are the same. Did a quick search and could not find the answer
Old Jun 28, 2002 | 05:17 PM
moore82nd's Avatar
you will need to buy a new trans cross member you can get them thru spohn
Old Jun 28, 2002 | 06:16 PM
JAY87GTA's Avatar
Yes the mounts are the same. As long as you got a crossmember to put on it's an easy swap. Good luck
Old Jun 28, 2002 | 07:48 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
yes, but if you buy a spohn x-member his are drilled for the ES mounts or mid 60's tranny mounts that utilize two bolts instead of a single threaded post.
Old Jun 28, 2002 | 09:35 PM
JAY87GTA's Avatar
The ES mount has all 3 holes in it anyway, so you can use either pattern.
Old Jun 29, 2002 | 02:41 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Cool. My x-mem came on Thurdsay. Spohn was cool enough to let me get the x-member w/ d/s loop and mount for torque arm since I can not afford the whole kit right now. I'll just use my poly bushing off my old 89.
Thanx for the fast response. I'll be shifting 6 by Sunday!!!!!! :lala:
Old Jun 30, 2002 | 12:29 AM
TBI305Camaro's Avatar
is the t56 swap to hard? im loosing 3rd gear and noway am i having the 700r4 rebuilt. i figure i need to start reading up and trying to get enough info to do the swap
Old Jun 30, 2002 | 12:49 PM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
did you start the swap?? you are going to help me when i get my swap started .... happy birthday by the way mike...
Shawn
Old Jun 30, 2002 | 04:59 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Not done yet. Waiting till the temp gets below 110 before I start today .... maybe the hang over will be over by then too. I got lots to do today. I'm swapping out the entire front susp from my old 89 to the 90 first, then I'll go to the trans. I already got the 700R out, and that was easy with the right tools. For the trans bolts, I used a 2 ft extension w/ a swival on the end. I dropped the trans down to tilt the motor down to expose the bolts better and helps to get the toque arm off also. Undo the top bellhousing bolts first so they are not the last ones that hold the assembly together. 6 bolts there, 3 on the flywheel to converter, disconnect all the linkages and wires and is down. Took only about 1.5 hours by myself.
Thanx Shawn I'll try to get a hold of you today to get you those WS6 springs. I hope I get a lot done today.
camaro11j
Sep 19, 2018 08:49 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
cRoe4
Aug 7, 2015 08:46 PM
