Th 350 shift points
Old Jun 30, 2002 | 11:22 AM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
Th 350 shift points
OK I know i need to use the vacum modulator to adjust the shift points but how do i use it. what do i do... i know it sounds dumb but i am use to my old 700, so please don't mind my stupidity in this subject... thanks guys
Old Jun 30, 2002 | 02:36 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The stock TH350 shift points are fine why mess with them?
If you must change them an aftermarket modulator has a different vaccum diaphram, firmer diapharm= later shift points softer= sooner.
Old Jun 30, 2002 | 11:26 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
I have an after market tranny in the car. my car is... or atleast was an 87 iroc but i destroyed my tranny with my crate motor so i opted for a tranmission that is a little stronger. anyway i have the good vaccum modulator that everyone one the board told me to get but how do i adust it so get higher shift points. right now, while i am not on the throttle much my car shifts way too soon so i need to adjust it.
Old Jul 1, 2002 | 03:49 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
pop the hose off of the modulator...and get a flat screwdriver that will fit in the hole...... turn the screw inward ..i believe to raise the points... its pretty cool...
Rob.... did you get the one with the red band ??? i just parked my car on a curb.. to get under ....
it..
rob
Old Jul 2, 2002 | 11:27 AM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Thanks a lot.... i got the one with the red band so ill see what happens. once again thanks soo much
Old Jul 2, 2002 | 01:55 PM
Car: 1983 Z28 Clone
Transmission: TH350
i'm going to back the screw all the way out... then put a little ..valve inline ....then run that into the cockpit.. soo i can adjust that while i'm driving ...copper tube of coarse..
Old Jul 3, 2002 | 04:10 AM
transfixleo's Avatar
Be carefull messing with the Vaccum to the Modulator. You can smoke the Tranny if things go awry. What are you trying to accomplish?
If you are looking to change the WOT shift points, STOP! You will have to do this via the Governor. Ideally the Modulator should be set so that as you just begin to move the pressure begins to rise. It is not and old radio where you dial in the station you want-there is a correct setting.
Old Jul 3, 2002 | 01:25 PM
Car: 1983 Z28 Clone
Transmission: TH350
well all i know is that it raises my shift point pretty good.. or lowers them....i have mine set close to stock right ..now..........
Eric-86sc
Aug 24, 2015 09:01 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
gwade12
Aug 8, 2015 08:17 AM
