how do I know what series carrier I have?
Old Jul 7, 2002 | 11:04 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
It is out of an 85 or 86 formula with drum rear, 4 speed at, and an injected 305.
10 bolt too.
Old Jul 8, 2002 | 01:07 AM
can anyone help??
Old Jul 8, 2002 | 06:40 AM
ede's Avatar
ede
you can buy gear sets for any carrier in any ratio avaiable. all you need to know is what ratio you have now. look in a catalog and you see x:xx ratio for y:yy and numerically higher carriers. it's that easy, and i figure you're asking because you want to change gear sets.
Old Jul 8, 2002 | 07:51 AM
BigRuss's Avatar
Probably the quickest and easiest way is to check the front of the axle housing on the passenger side for the factory stamp. Bring a scrub pad and lots of degreaser and you'll eventually find it. Match this up to the code in your Haynes manual or other source and you've got the axle ratio. If it's a 3.42 or 3.23, you've got a 3-series carrier. 2.73 is 2 series... just go by the first digit and that's what series you have.
If you have any concern about whether someone has changed the gears before, you can't go by the stamp. At this point, you can pull the cover and count the teeth on each gear, then divide the ring gear by the pinion gear and you've got it. Or, you can spin the tire and compare the rotations to the number of rotations on the driveshaft.
Old Jul 8, 2002 | 10:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look.
Have you changed the fluid lately? Then you need to pop the cover anyway.
Old Jul 9, 2002 | 07:37 PM
I have 3.08's in there. I think I need a spacer because the edges of the teeth are ruined. How do I know if I need a spacer??
I want to put in 3.73 gears. What do I need to do??
Old Jul 22, 2002 | 11:59 AM
82camaro's Avatar
Car: 82 camaro SC
3.08's, if they are factory, are 2 series. You need 3.73's for a 2 series carrier. Richmond makes em'. Summit racing carries them. As far as spacer, I think you mean shims. You won't know what shims you need until you install the new gears. You will then have to 'set them up' or have a shop do it.
Old Jul 22, 2002 | 12:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, you need either the thick gears or a ring gear spacer. I would recommend the spacer, because then you can still use the gears in their intended application; for example, you could get a SLP posi unit (which are all 3 series), and they would fit by leaving the spacer out, where if you use the special thick gears, you're stuck with a 2 series carrier forever.
Old Jul 22, 2002 | 01:05 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
where can you get a ring gear spacer for a 7.5 inch rear?
i looked for over a month and never found one, i'll be pissed if someone proves that there is one availible, cuz it'll mean i bought a second set of gears for no reason
Old Jul 22, 2002 | 01:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
www.drivetrainspecialists.com
Go to the GM 7.5 page. about 12 lines down from the top
IK83-0750 $55
Old Jul 22, 2002 | 01:30 PM
Car: 1984 Firebird
Axle/Gears: 4.10
well thanks for the page, i wish i had found it last september, oh well, did i see correctly on that page that you can buy new clutch packs, and such for the factory posi?
Old Jul 22, 2002 | 01:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks that way... I don't know too much about that though
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
