Not sure if i have 2.77 or 3.27 rear-end?
Old Aug 7, 2002 | 10:45 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
I've done research on the net, and some show my year to have the 3.27, and some say 2.77. I thought 3.27 were standard on 1987 GTA with a 350. But now i'm not sure. Is there anyway to find out for sure. I mean i know there is, but an easy way.
I doubt the car will have it labeled anywhere. Would the VIN number show me?
G2PW2185HN231441 <-----VIN # Hopefully some of u guys can figure it out with this.
If not not, any other way to find out for sure?
Old Aug 7, 2002 | 11:17 PM
scott92RS's Avatar
Car: 92 Firebird
Engine: 350 TBI/LT4 cam
Transmission: 700R
Check out the tech data of Thirdgen's homepage. The 3.27 gears is standard for the 87 GTA with the 350. My 3.27 gear with rear disc brake came from a 87 Trans AM GTA 350 TPI. Its going on a 92 Firebird 305 TBI soon to be a 350 with a LT4 cam rated at 300HP.
Old Aug 7, 2002 | 11:29 PM
fattie92's Avatar
get the rear end off the ground enough for the back tires to spin. make sure the car is in neutral.(BLOCK THE FRONT TIRES!!).. with a peice of chalk, mark the tire and the body. have someone else hold the tire to make sure it doesnt move and crawl under the car and do the same to the driveshaft.one everything is marked, have your partner rotate the tire, and count how many times it takes for the driveshaft to make 1 revolution. if its close to 3 but not completely 3, then you have a 2 series, if its over 3, then you have a 3 series.
hope this helps
Old Aug 7, 2002 | 11:33 PM
GTATransAM's Avatar
hope this helps
Wow, didnt think u can do it like that. I might try that if it comes down to it, thanks.
Old Aug 7, 2002 | 11:38 PM
fattie92's Avatar
no problem.. i didnt know you could do that till bout a month ago
Old Aug 8, 2002 | 12:25 AM
Darth_TransAm's Avatar
You do have a 3.27 rear in your GTA.
I have owned and dismantled many Firebirds. The 350 87's all had the 3.27.
There should be a tag that is bolted (riveted) to the housing that would tell you the gear ratio. You just have to get under the car and look for it.
Old Aug 8, 2002 | 04:05 AM
scott92RS's Avatar
Car: 92 Firebird
Transmission: 700R
Darth_TransAm, is right the tag on the rearend should have the part number and gear ratio.
Old Aug 8, 2002 | 06:02 PM
GTATransAM's Avatar
Hey fattie and scott, thanks. U have made me rest assured that i have 3.27 now.
But when i get to it, i'm gonna check the rear end just to be 100% sure u know.
But anyways thanks again.
Old Aug 8, 2002 | 09:18 PM
scott92RS's Avatar
Car: 92 Firebird
Transmission: 700R
GTATransAM,nice car dude I got a friend of mine who has the exact car and color except its a 88 with a LT1 motor put in it. Man I have the slowest car so far but before Christmas I should have my new 350w/LT4 cam and I'll really be smoking tires.
Old Aug 8, 2002 | 09:32 PM
GTATransAM's Avatar
Hey thanks scott. I wish i had the LT1 engine, or even LS1. In fact thats what i wanted to get in the first place, but i kept getting tired of seeing to many LS1s on the road, so 3rd gen was my choice. And believe me i really love 3rd gen even though they slower in stock format than LS1 and LT1. And let me tell u, i get ALOT of head turnings when i drive by, its unbelievable.
To bad fall and winter coming up, it will be back to my 93 grand prix until next spring But hey its the best way to garage it.
Thats gonna be awesome when u get that 350. U should keep it "RS" looking to make it more of a sleeper, not that your car is slow, but hey you;ll hang with the 350 guys even though they dont think u can, that'll be fun. Good luck with that!
U doing the engine swap yourself, or u getting it done somewhere?
Old Aug 9, 2002 | 02:29 AM
scott92RS's Avatar
Car: 92 Firebird
Transmission: 700R
I'm getting someone elso to do it for me and I will do the tweaking for top performance cause I too busy with work while spending time with my 2 years old girl. But ,in the meanwhile, I'm getting ready to slap on my 3.27 rearend and enjoy the disc brakes. LOL
92projectcamaro
Dec 8, 2015 12:25 AM
92projectcamaro
Sep 29, 2015 07:07 PM
TexasMaro
Sep 15, 2015 06:50 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
