Please reply asap: B&m trans pak. is it the bad one.
Old Aug 8, 2002 | 12:44 AM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
I am rebuilding my 700 tranny. I have a choice of the standard rebuild or the b&m trans pack with the better clutches and other stuff.
You guys say that the b&m is bad for the tranny. Is this one okay to use???
Old Aug 8, 2002 | 02:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Anything by B&M is bad.
Old Aug 8, 2002 | 05:16 AM
Pro Built Automatics's Avatar
Stay away from B&M. If you need the right parts (that work), call me at 800 7763288 M-S 10-6 PST, and I will be glad to help?
Old Aug 8, 2002 | 01:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The trans pak isn't a rebuild kit.. it's a shift kit.
There's NO difference between the $25 Shift Improver Kit and the $45 TransPak for the 700r4 automatic!!! None! Okay, well, there's one- the TransPak comes with a new filter. That's it! I can get a 700r4 filter from Pep Boys for $10.
Pro Built, are B&M's rebuild kits bad also? I thought it was just their shift kits.
Old Aug 8, 2002 | 03:44 PM
the kit the guy wants to use is the b&m rebuild kit. It has better clutches and other things too.
What do you guys think. Shell out the cash or just go with the stock rebuild?
No transgo right now. I have no money. too bad for me.
Old Aug 8, 2002 | 04:03 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
B&M shift kits suck... they bang way to hard and cause the tranny to blow... I am speaking out of experience. I hear nothing but good things about TransGo... and the probuilt guy definetly knows what he is talking about... so avoid B&M if at all possible.
Old Aug 8, 2002 | 04:33 PM
so even the b&m clutches would be bad?
The guy tells me they could last a bit longer than the stock.
Wouldn't the b&m be better than no shift kit at all?
Thanks for the help guys...As usual.
Old Aug 8, 2002 | 04:35 PM
Remember this is the full kit with b&m clutches and bands and stuff. This is not just the shift kit.
Is this better for me to use than stock or should I go with the regular rebuild and have no shift kit???
My option is b&m or nothing. that is it.
Old Aug 8, 2002 | 05:52 PM
transfixleo's Avatar
I would avoid it if I were in your shoes. I would just asoon see you use the 4L60E factory Clutches and Band.
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Dquickshift
Aug 12, 2015 06:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
