T56, now car wont start
Car: 1989 IROC-Z
i tried starting my IROC last night after we did the swap and it just turns, it wont start. hooked up a fuel pressure gauge and got nothing. anybody know why? we took off the fuel pump relay in the process but we checked that and it is on correctly. can anyone help?
Car: 87 IROC (looks like 91-92 Z28 tho huh?)
Engine: 355
you said you have no fuel pressure right? If that is the case then, first thing I would check is to see if the pump is working. If not, I would get out a multimeter, and see if it is getting power.
If not, then I would probably check things to do with the relay since you mentioned that you tinkered with it. Check connections etc. If nothing pans out there, then I would check to see possibly if you may have crimped a fuel line or something, when moving the tranny into place.
If that doesn't work, then ???? - have to think some more for a bit.
-Shaneo
-Shaneo
BlackphantomZ28
Aug 31, 2015 10:29 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
