How much power will a T5 handle???
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I did osme searching but i am still not clear on this.
I know a 305 T5 combo is ok but where does the limits come in. People have had 200+ HP v6s. Is it the Hp or Torque that the T5 cant handle?
stock 85 305 im getting 155 HP 245 Torque. like to ais it too about 200+ HP but where is the breaking point for the T5. 3-400 Torque???
Car: 1986 IROC-Z28
Engine: 355 in the works...
The torque is what kills the tranny. I believe the torque rating on them is ~300ft/lbs but I'm not positive. As with most things, if you abuse it, it WILL break.
Car: '97 Z28
Engine: 5.7
Transmission: M6
No, there are a lot of different versions. Not long ago there was a link to a site that listed the different ones. Maybe someone can come up with that again.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
not sure about the fords but I remember dude in highschool buying a shiny black 80s mustange and he was riping 5 speeds aparts like every few months. Sure it was the T5.
I was thinking if I could get the motor up to around 250 hp but keep the torque around 300 I owuld be cool.
But how do you rais Hp with out raising torque???
305 im getting is free and strong, 85 mostly stock but has headers. thing will just spin around in circles smoking the tires if you hit the gas and dont correct it.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Originally posted by Gumby
But how do you raise Hp with out raising torque???
That's why the 302 and 327 engines rev'd so high. A 302 chev was capable of running high rpm all day long. That's where it built it's power.
You get 305's for free because they are only good for a stock replacement engine not a performance engine. Anyone serious about finding performance will at least use a 350 engine.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I'm frankly very surprised at how strong my little old 305 is running!
And it will all fit right onto the 350 when that day comes along.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Big bore, short stroke. Something like a 302 or 327 crank in a 400 block.
