torque arm mount, where?
Old Oct 6, 2002 | 09:07 PM
quick_90's Avatar
ok i just bought my 90 camaro rs and the tranny is out. this whole torque arm thing is new to me cause for 6 yrs. all i've worked on were 2 68 camaros. soo ... what does the front of the torque arm mount to? the tranny or a seperate mount that hooks to the tranny mount. also i bought a 700R4 that i plan on useing and there are no holes for a torque bar if thats where it mounts. also putting this behind the (getting built) 383 stroker. should be a reallllll mean 5.0 killin machine
thanx for the help
Old Oct 6, 2002 | 10:42 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you need to swap on an 82-up camaro firebird 700r4 tailshaft housing, hey you are close to me over there, maybe when i get this 700r4 swapped out for my th350 and swap out the 305 for the 350 i have we can go stomp on 5.0L's together
what gears you got in rear ? 3.23 here
good luck
Old Oct 6, 2002 | 11:03 PM
EvilCartman's Avatar
Car: '82 Z28
82's didn't come with a 700R4
Old Oct 6, 2002 | 11:29 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Click on the link below and it should lead you to a tech article on how to R&R the speedometer gear.
http://www.sethirdgen.org/vss.htm
The first picture of the back of the transmission shows you what the torque arm mount looks like and it's location. In that pic, it is to the left of the output shaft. It is what looks like a 3.
In the third picture, the hand is grabbing the torque arm mount.
There are also two types of torque arms. They look like 3's and E's.
The mount is a clamshell style and bolts to the tailhousing. I would suggest buying a $15 Energy Suspension poly mount for it while you are at it.
Hope this helps,
Jesse
Old Oct 7, 2002 | 12:12 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
well yeah true in third gens anyways, but stil same principle...
why GM didnt offer Auto OD in 82 i duno if anyone knows..
wierd..
Old Oct 7, 2002 | 09:36 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
wierd..
simple. i'm pretty sure it didn't exist yet
Old Oct 7, 2002 | 12:43 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
false, 82 was first year for it, so.,,,,,,
read here for one: http://www.technicalevolution.com/700r4.htm
Old Oct 7, 2002 | 12:47 PM
Car: 1984 Firebird
Axle/Gears: 4.10
i apologize, i was wrong. BUT, they were not standard untill 84 in f-body's
Old Oct 7, 2002 | 03:29 PM
quick_90's Avatar
well guys there has been a change in plans, ive looked around searching and it seems to me the way to go is a 350 turbo.sooo thats where im goin with it.
thanx for the help
any suggestions on which conversion kit to go with?
Old Oct 7, 2002 | 09:22 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
no need for apologizing, i just meant that 82 was first year in general for GM AOD trannies, , thats all, sorry
B&M tranny tail brackets kit 130-30299
https://www.thirdgen.org/techbb2/sho...hreadid=136525
http://www.jegs.com/cgi-bin/ncommerc...15&prmenbr=361
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
