Tips on getting my VSS outof the tailshaft?
Old Oct 6, 2002 | 10:17 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I'm just finishing up my swap in my Trans am. I have a 700R4 that came with the T/A that has the VSS sending unit in the tailshaft, and a TH350 that came with my old Camaro that has a 700R4 tailshaft. (which I am taking the engine/tranny out of to put in my T/A).
My problem is that I can't get the VSS sender out of the 700 to put in my 350. I pulled the one on my TH350 already (which is metal) and it came right out. The one in the 700 is plastic and I've already broke a tab off of it trying to get it out with channel-locks. Is there something I'm missing. I've almost pulled off this entire swap without a problem (knock on wood) and can't let this little piece of plastic defeat me.
Thanks for your time,
Matt
Old Oct 7, 2002 | 05:13 PM
jonarotz's Avatar
Car: 91 Z28
All that holds the VSS in is the little bolt and the clamp that looks like a distributor hold down. After the years this thing can seat itself in there pretty good. It has an o-ring that is what is probably holding you up. You could probably try to spray some penetrating oil around it. Hopefully that will loosen it up. Good luck with it.
Old Oct 7, 2002 | 07:23 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I have a couple extra retaining clips that holds the driven gear in place on the output shaft incase you break yours and need another.
Old Oct 7, 2002 | 09:54 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
Alright, I just wanted to make sure there was nothing I was missing before I broke it. The cable driven one came right out of the 350 with just a little twist and pull, I will try some penetrating oil.
Thanks for the offer Tom, but between the trannys I have two so I should be fine. BTW, my stepdad's lawn service has a truck with a 454 TBI, what is the differance between that one and the ones that comes on small blocks? It's cool to see someone do something differant.
-Matt
Old Oct 7, 2002 | 10:32 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Pretty much the only two differences is the 454 tbi has 2" bores instead of 1-11/16' like the smallblock TBI's, and the injectors are bigger too.
Old Oct 21, 2002 | 12:41 AM
z28_dave's Avatar
From: tokyo - where the girls are pretty and the cars are fast
what a gentleman
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Thaney9
Oct 15, 2015 06:37 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
