Driveshaft leghts....
Old Oct 11, 2002 | 08:40 PM
1982chevycamaroz28's Avatar
okay hopfully by next summer ill be gettin a supercharged 355 with a powerglide tranny. the thing is will my driveshaft be the same lenght for the tranny swap. i have a th350 tranny dunno what size tail shaft yet but ill find out but would my drive shaft work or will i need a new one?
Old Oct 11, 2002 | 09:17 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
depend son what lengthg of 350 you have now, i think P/G are length of short tail 350, im pretty sure, so you would be ok if you have short tail now, but if not then you would need a thm200c driveshaft and that shaft is longer than shaft for all other tranny models used in these cars, except for maybe Sag 4 speed
good luck
Old Oct 11, 2002 | 09:33 PM
so if i have a 6in tailshaft ill be fine but if i have a 9in tailshaft id have to get a drive shaft from a th200c tranny? what cars or where would i look for a driveshaft from a th200c tranny?
Old Oct 11, 2002 | 09:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If this is for a daily driver I can tell you right now that you're not going to like the powerglide. Although it's a nice race tranny with only one shift, that first gear sucks for street driving.
Stick with the TH350 or upgrade to a TH400. The extra gear will make a big difference.
A 9" tailshaft TH350 is close enough to use the same driveshaft as a 700R4. The 6" tailshaft TH350 needs the longer driveshaft from the TH200. You can find the longer driveshaft in 82-83 f-bodies that came with the 3 speed auto.
Old Oct 11, 2002 | 09:54 PM
well once i get this enegin and tranny combo put in i doubt it will be daily driven much. besides to go to the local car show every wed. night but besides that it will be a track car only.
Old Oct 12, 2002 | 09:25 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
no, 200c is shorter tranny than a 9" th350 and 700r4 and T5
powerglide should be 3" shorter, IE; same as 200c which is the only factory 3" shorter tranny installe din third gen cars other than the 4 speed sag in which i am pretty sure is 28 5/8" or so overall length with bellhousing included, same basic length as a 6" th350 and thm200c
Old Oct 12, 2002 | 01:35 PM
82camaro's Avatar
Car: 82 camaro SC
Skip the powerglide, unless you run a absolute killer engine, really deep gears, and a light car(you will have to lighten a 3rd gen quite a bit) a powerglide will be slower--race or street. 1st gear is usually 1.76 or 1.82 in the 'glide, which is a bit deeper 2nd gear in a th350's 1.52 ratio. It will almost be like launching in 2nd gear with your current tranny.
Old Oct 12, 2002 | 06:39 PM
well they guy im gettin the engine from said he got into the low 11's on street tires in his old nova he used to have. but if i do stick with the th350 would i have to beef up the tranny any? i just got a tune up and when the tranny was swapped in the guy installed a shift kit. what else could i do?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
