Axle Question
Old Nov 9, 2002 | 08:29 AM
DozaChris89TA's Avatar
Are axles different for drum and disc brakes???
Dose anybody know if the rear drum brake axle is the same as the rear disc brake axle. If not what rear axle's will fit my 89ta with disc brakes. Thanks
Old Nov 9, 2002 | 02:54 PM
AHH...
someone must know the answer to this question!!!....
/me rephrases the title...
Old Nov 9, 2002 | 03:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To my knowledge the flange on drum and disk brake 10 bolt axles are the same.
Old Nov 9, 2002 | 03:53 PM
4L60bliss's Avatar
Actually, the backing plate flange is different, but I have seen people cut off the excess that a drum setup has and re-drilled for a disc backing plate.
Old Nov 9, 2002 | 05:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
He never asked anything about the brake setup. Just if the axles themselves were the same. A drum and disk brake mount is different because of how they're mounted on the diff housing but that has nothing to do with the actual axles.
The flange I'm taking about is the part that the wheel bolts to. The drum or disk slides over the flange.
Old Nov 9, 2002 | 06:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some years, some of the drum axles had a flange that's too large outer diameter to fit inside a rotor. But not all. Other than that, they're the same.
Old Nov 9, 2002 | 07:51 PM
4L60bliss's Avatar
Oooops, I read to deep into the post...
I don't think a disc rotor will fit on a drum axle, like what was mentioned.
Old Nov 9, 2002 | 09:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I wish I still had my factory axles. The aftermarket 28 spline axles I have for a 10 bolt will work with both.
Old Nov 9, 2002 | 09:44 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Axles
I have installed several sets. I did run in to one set of rotors that did not fit right, but after a little grinding on the inside radius, (where the edge of the axle sits) it cleared alright. On the earlier disc brakes the rotors are smaller on the inside so you have to use the early disc axles.
Old Nov 10, 2002 | 05:57 AM
thanks
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Genopsyde
Oct 7, 2015 08:35 PM
downsouthboy
Aug 29, 2015 11:29 AM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
