HELP ! How do you take off...
Old Dec 5, 2002 | 07:40 PM
giff's Avatar
Car: 91 G92 Formula, 35k original miles and owner
Transmission: 5 speed
trying to install my new hurst shifter and can't seem to get the shift **** off or the shifter boot. what's the trick on these? the **** won't seem to screw off...
also, i can see how the console unscrews (2 screws in back and 1 in the middle) but what is the easiest way to get if over the e-brake? i've already taken off the e-brake handle piece (plastic "cover") but it looks like i'll have to slide the console forward about 4 or 5" to get it off but there is no room. ???
any help would be much appreciated!!!
giff
Old Dec 5, 2002 | 07:42 PM
giff's Avatar
Sorry !! 91 formula, 5 speed...
Old Dec 6, 2002 | 12:17 AM
vrooom305's Avatar
This I think I can answer correcty...
The shift **** does screw out counter clock wise, just ask someone stronger than you to try to take it out (that's what I did). As for the e-brake, I pulled the ebrake as far as I could (I would say about a 70*-80* angle) while pressing the "button".
Hope it helps...
Old Dec 9, 2002 | 07:05 PM
giff's Avatar
Thanks. Got both off with no problem. I knew I could probably muscle the shift **** off but did not want to bend anything in the process. Experience has taught me to ask when in doubt !
Giff
Old Dec 9, 2002 | 07:39 PM
camzcruizer's Avatar
theres actually a very small c shaped clip on the auto shifter kknob, well on nmmine anyway but i guess you already got it off
Old Dec 9, 2002 | 08:54 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
he said its a 5 speed
gta892000
Aug 11, 2019 11:16 AM
Camarothatcould
Aug 20, 2015 08:49 AM
Xenodrgn
Aug 20, 2002 01:16 PM
davecamaro
Mar 10, 2002 12:11 AM
Xenodrgn
Nov 25, 2001 03:19 PM
