Manual Shifting on Auto Trans
Old Dec 13, 2002 | 09:33 PM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
I've heard many people say that too much manual shifting on an auto trans is bad for it. Is this true? And if it is, why? What does it do that's different from normal shifting?
Old Dec 13, 2002 | 10:34 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I don't know how bad it is. but you if start from a stop and drop in into first and shift each gear till overdrive you can take it to redline or higher each time. if you just have it in over drive from a stop i think it shifts before red.
Old Dec 14, 2002 | 09:07 AM
demonkey36's Avatar
Car: 1991 Camaro RS
I don't know....I've just heard a few people on here say that too much manual shifting after a while will mess up the trans.
Old Dec 14, 2002 | 12:34 PM
Pro Built Automatics's Avatar
As long as it upshifting and very little manual downshifting your probably ok. Adding the largest intermediate reverse boost valve, larger primary boost valve, and Corvette servo would help out some along with the Performance Trans-Go Shift kit.
Old Dec 14, 2002 | 01:01 PM
kevinc's Avatar
Car: 1982 Z28
On the manual downshifting side, ask yourself which is easier to replace: brake pads or clutch packs? I'll take brake pads any day over a trans rebuild.
Old Dec 14, 2002 | 04:11 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Well I think more by manual downshifting for racing purposes not for slowing down for like a stop sign or something. The type of driving I do requires alot of upshifting and downshifting. And now my trans went to crap O_o
Old Dec 14, 2002 | 07:49 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
My car had a 200C in it which died at 100K miles - thankfully that tranny is gone.
I drive the car hard through corners and I used to down shift a lot because I don't like the way an automatic sort of freewheels through corners when it's in drive.
It seems that you can set the chasiss better both into and through a corner with it in a lower gear and some revs on the tach rather coasting through in drive.
Also, at hard lateral g I don't want the tranny to suddenly downshift when I get on the gas thereby unbalancing the car at bad time.
Point being that you have more control when you pick the gear you want and then balance the car on throttle during hard cornering.
I found that by downshifting and then giving it a shot of gas the tranny shift smooth enough. No doubt this contributed to its untimely demise though.
The 200C was very loose shifting even at its best.
What I'm wondering is whether you could shift say a 350C with a shift kit in the same manner I've described without wrecking it because I think a 350C will be my next tranny.
Old Dec 15, 2002 | 02:03 PM
bradkeith's Avatar
George, i know exactly what you're saying about an auto shifting during a turn. I had a near-death experience in my 86 camaro going around a corner in d on the gas, it downshifted and kicked sideways. I had to use the e-brake to pull it out of it. damn autos!!!
Old Dec 15, 2002 | 02:53 PM
REVLIMIT's Avatar
Engine: Built L98
Heh? Your car shifted during a turn causing oversteer. So you used your ebrake to come out of it? The ebrake would cause more oversteer because it would lock up the rear wheels. O_o
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
