Kiwi newbie: Re shift points
Old Dec 14, 2002 | 08:02 PM
Kiwi-85IROC's Avatar
G'day lads this is my first post.
Reading several posts on TV indent issues, I still have a question on up shifting through the auto.
I just yesterday bought a beautiful 85' IROC travelled 59 miles, it drives great. Only issue I have and I'm not sure if it normal or not is this:
Under 1/3 to 1/2 throttle it changes very quickly from 1st to 2nd to 3rd gear in like 5 secs. I can't seem to get it to stay in 1st or 2nd any higher than 2500 rpm. I adjusted the TV thingy as instructed in the Tech articles section.
Is it normal to go into 3rd gear so quickly?
Cheers: Wayne
Old Dec 14, 2002 | 10:02 PM
82camaro's Avatar
Car: 82 camaro SC
At light throttle that's OK. Your engine has enough torque at low rpm that it doesn't need to rev much. When does it shift at full throttle.
Old Dec 14, 2002 | 11:32 PM
Thanx for the reply mate.
Went down the road to try it out under full throttle.
Planted the accelerator and it changed to 2nd almost immediately, maybe got to 3,000 rpm!! bugger me :-)
Whats that all about?
Cheers
Edit: Come to think of it, it doesn't kickdown either or not very much...does from 4th to drive, but I haven't seen it do it from 3rd to 2nd.
Old Dec 15, 2002 | 12:08 AM
Mate I fixed it!!!! After thinkin about it not kicking down, I thought it must be the TV cable not right...so I searched "kickdown" in the forum and someone mentioned a "transfixleo method " which said it a little differently...anyways I was not adjusting the TV cable correctly...when I did..WHAMMO!!! differnet car to drive!!!
Thanx heaps for askin about WOT, got me thinkin on a different line of thought and fixed the prob.
Cheers and Merry Xmas mate.
Old Dec 15, 2002 | 12:56 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Welcome to the board and best wishes for Christmas and the New Year to all you buggers in New Zealand and Australia who drive these cars.
Old Dec 15, 2002 | 02:02 AM
Good on ya mate...hehe for sayin "buggers" most excellent! :hail:
Old Dec 15, 2002 | 10:13 AM
82camaro's Avatar
Car: 82 camaro SC
If you haven't already, change that tranny fluid and filter--it may have shifting like that for quite a while and burned the fluid. While your at it change the diff fluid too(posi additive if needed). 4th to 3rd will probably always happen--chances are your 700r4 doesn't allow full thorttle in forth gear at any speed. Welcome to the board.!! Sounds like you are off to a good start--you are searching the boards, which is something new users have trouble doing.
Old Dec 15, 2002 | 01:24 PM
CC will do...thanx for your help.
Wayne
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
