t-5 speedo gears
Old Jan 3, 2003 | 04:06 PM
Fastcamaro87's Avatar
t-5 speedo gears
ok i have searched and read all the info i could find about this subject and i am still unclear on which gears i need.
My car came from the factory with the g92 option, 305 tpi 5spd with 9-bolt 3.45`s, my current speedo gears are a purple 7-tooth drive gear, and a light blue 20 tooth driven gear. I currently have a 3.23 10-bolt installed and i would like the speedo to work correctly. Which drive/driven gears do i need for 3.23 gears? I also have a red 21 tooth driven gear from an old 84 z28 t-5 will this be of any use?
In the future i will be putting 3.73`s in and i will need the correct speedo gears for this setup as well, can someone please tell me what gears i need, part numbers etc, for these 2 combos
I am running a 245/50/16 tire.
thanks in advance
Matt
Old Jan 3, 2003 | 04:20 PM
ok i just checked out the calculator on Hanlon Motorsports site, and according to it i need:
3.23 : 7 tooth / 16 tooth
3.73 : 7 tooth / 21 tooth
so if this is correct, i already have the correct speedo gears for the 3.73s and all i need to locate is a 16 tooth gear. does anyone know the part number for this?
Old Jan 3, 2003 | 04:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is not right.... 3.23 gets a 19-tooth IIRC
Old Jan 3, 2003 | 04:36 PM
19 tooth?
so for 3.23 u are saying i need a 7/19 combo? RB83L69
Old Jan 3, 2003 | 05:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I believe that is correct.
Old Jan 4, 2003 | 10:39 AM
ok in a few other posts i have read, a few people have stated that there cars with factory 3.42 gears came with a purple 7 tooth drive/ and a white 19 tooth driven gear, however RB83L69 is saying that this combo will work for my 3.23 gears, how is this possible? also from what i have read an 18 tooth gear would be a better one to get, does anyone know the part number for the 18 tooth driven gear?
thanks
Matt
Old Jan 4, 2003 | 02:28 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
My car has 3.23's and I just swapped a T5 in. I COULD NOT find any car that used a 5-speed/3.23 combo to get speedo gears from. What I ended up doing was installing 3.08 speedo gears. Now my speedo reads a bit faster but not much. When I'm going 28mph, my speedo reads 30 mph. I have the 3.08 gear info if you want it.........
Old Jan 5, 2003 | 12:58 AM
yeah, CaliCamaro, any info would be very helpful, thanks
Old Jan 5, 2003 | 03:06 PM
Engine: LH0 3.1L
I don't have the PN's but I do have the colors:
3.08 Gears for T5 only---
-DRIVE: RED w/ 9 teeth
-DRIVEN: GRAY w/ 22 teeth
Just tell the GM parts counter this info. The parts catalog lists all the gear colors and tooth counts for easy ID.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
