For anyone who has put a TH350 in your thirdgen...
Old Jan 8, 2003 | 04:49 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Ok guys, bought an 83 Z28 parts car that someone put a Turbo 350 in. The torque arm hasn't been bolted to the transmission, instead they have it bolted to the transmission tunnel. What I'm asking is, I know there is a kit (made by B&M and Hurst) with a bracket to bolt the torque arm to, but I'm not up for paying 95 bucks for the kit. Anyone have any cheap solutions?
Old Jan 8, 2003 | 07:13 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
B&M/Hurst is the cheap solution. The best solution is an aftermarket torque arm like Spohn that attaches to a new crossmember.
Old Jan 8, 2003 | 07:59 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I'm not 100% sure here, but I have overheard stories that the tailstock from the 700r out of a third gen will fit on the th350..Like I said not 100% sure, but worth looking into. HTH
Keiran
Old Jan 8, 2003 | 09:12 AM
rjmcgee's Avatar
I think your 83 parts car has the cheap solution. The B & M kit is good and IIRC about $70 from Summit.
Old Jan 8, 2003 | 06:22 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
i just made my own bracket from steel, measuerd and cut and welded up around the tailshaft. it bolts into the 2 left side tail shaft holes, and a whole cut in the middle allows for speedo sending unit.
Old Jan 12, 2003 | 07:31 PM
realfast89's Avatar
what do you think of this
im changing out my th700r4 for a th350 and im going to weld in a new cross member behind the old one and bolt the toque arm to that . think that will work
Old Jan 12, 2003 | 11:24 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
no
do a search and see exactly what you need.
Old Jan 13, 2003 | 05:36 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Keiran
definetly not
Old Jan 14, 2003 | 09:15 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
You have the cheapest solution. I have a SouthSide Machine kit on my car which eliminates the torque arm altogether, allowing you to use a turbo 350 and a 9" Ford rearend without any special bracketry to attach the torque arm. (I haven't put the 9" in yet) Of course, the kit is $489.99 at Summit.
The bracket you spoke of is the way you should go. You could always order one, take all the measurements and build your own, and then send back the one you ordered...
Old Jun 21, 2003 | 12:51 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
anyone put th350 in yet with B&M brackets, how do they mount to tailshaft housing ? just under the bolts, or between case and tailhousing ?
Old Jun 23, 2003 | 10:33 AM
ChellysCamaros's Avatar
Between the bolt and the tail housing....I just did this swap myself and couldnt afford the $80....My husband has a job in a fab shop and they took a tail housing from an old th350 we had and built a bracket for me to my measurements....It works great....But will be buying the B&M bracket down the road....
Old Jun 25, 2003 | 02:01 AM
peacefrogs72's Avatar
drive shaft
So someone please give me the low down on the tail shaft, and the drive shaft, know that one is short and one is long......and long is the way to go (I think), but what about the drive shaft, will I need a new one, or need to refab my old one??
Old Jun 25, 2003 | 12:20 PM
Hiya Peace...ok....I dont know about the lengths of the shafts this and that...I do know that I am using the short shaft th350 and that I had to cut almost 4 inches off the driveshaft from my 78 camaro....the stock shaft from my T5 was bout 3 inches too short..
Old Jun 28, 2003 | 01:55 AM
Rancid87's Avatar
I have a Hurst brand th350 swap kit I never used. I'll let it go for $75 to anyone who is interested.
Old Jul 19, 2003 | 03:32 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
if your car is auto and not overdrive originally then you need short tail th350 from cars and vans, if was auto overdrive then you need longtail th350 from trucks
im using a van th350 in place of thm200c, both shorty*
Old Jul 22, 2003 | 09:24 PM
Racer3313's Avatar
Car: 1991 Camaro RS
Engine: 305 LO3
Transmission: TH350
Axle/Gears: Ford 9" 3.70 gears
I just converted from a T5 to a Th350 in my 91 RS. I would spend the $$ and get the crossmember-torque arm combo from Spohn. I did, the quality of the parts was excellent and everything bolts right up.
I had actually already purchased the B&M kit but sent it back.
Just my 2 cents.
MD
Jake_92RS
Jan 28, 2020 10:37 PM
LittleFranks
Sep 17, 2015 12:22 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
Fronzizzle
Aug 9, 2015 01:15 PM
