will a V6 700r4 work with a V8?
Old Jan 9, 2003 | 10:45 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
is it built the same?
thanks
Old Jan 9, 2003 | 10:59 PM
MotorCityMuscle's Avatar
No, it wont work. The bellhousing bolt patterns are different.
Old Jan 11, 2003 | 09:13 AM
Nordbert's Avatar
The bolt pattern for a 700-r4 from behind a 4.3 Chevy V-6 as used in an Astro van is the same as a small block Chevy. You should put the governor from the V-8 tranny in it to maintain similar shift points.
Old Jan 11, 2003 | 07:23 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
whoa
im confused..........so the firebird V6 tranny wont work.....but some van one will??
Old Jan 11, 2003 | 09:25 PM
Nordbert's Avatar
Strange, but true. The V-6 used in f-bodies has a different bell
housing bolt pattern than that of the 4.3 V-6. Stranger still is
that GM chose to use only the Chevy bellhousing pattern on the
700-R4. I'll never understand that one! :lala: :lala:
Old Jan 12, 2003 | 12:31 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well then............
thanks for the info
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
