replacing syncros on a WC t5
Old Feb 18, 2003 | 01:20 PM
will62085's Avatar
does anyone have any good websites that explain the process of replacing syncros in a WC t5? My third gear syncro is going out
Old Feb 18, 2003 | 03:20 PM
1fasZ's Avatar
www.hanlonmotorsports.com
They have t-5 manuals and also a t5 repair video.
Old Feb 18, 2003 | 08:20 PM
will62085's Avatar
okay, another question...occasionally it pops out of 1st...it happened like to weeks ago, and then again tonight, and reverse grinds sometimes...im gonna have to replace syncros, but what would cause it to pop out of gear like that?..what do i replace?...never rebuilt a trans before, but ive done rear end work so i know i can do the trans too
Old Feb 19, 2003 | 08:26 AM
1fasZ's Avatar
Sounds like your shifting fork is either broken or the little plastic pads on the shifting fork is broken. It is a pretty easy fix.
Old Feb 19, 2003 | 01:58 PM
will62085's Avatar
would that cause all of the above problems?...it would be nice to avoid having to rebuild it. thanks for your help
Old Feb 19, 2003 | 03:20 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
If you are thinking about only replacing the syncros, then you might not help the problem at all. There are more than just the syncro's affecting shifting in a T5. There are the little square "dogs" and the springs that hold then with the proper pressure against the slider that are also very important.
Best bet is to get the trans video from hanlon for $17 along with their rebuilt kit for around $160 and do it right the first time. The shifter fork pads are included in the kit. So for about $200 you can have a totally rebuilt trans.
Old Feb 19, 2003 | 04:21 PM
will62085's Avatar
yeah i think thats what im going to do, thanks alot guys
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
