t-5 tailshaft torque specs
Old Feb 22, 2003 | 04:29 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i need the tailshaft or housing torque specs for the bolts that hold it to the case. thanks
Old Feb 22, 2003 | 06:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Should be around 40-45 ft-lbs
Old Feb 22, 2003 | 11:18 PM
Car: 89 Formula
Engine: Carbed 5.7
ok thanks, i have that at 30 now so u will give it a little more to 40
Old Aug 16, 2019 | 11:27 PM
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
Re: t-5 tailshaft torque specs
I know this is an old Post but I can't have misinformation out there the tail housing to main body is 23ft.lbs
Old Aug 17, 2019 | 09:57 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
M10 x 1.50 steel bolts into alum. die castings will be fine at 23lb-ft or 40lb-ft. I go 30. On an application where you're assembling, then shimming bearings and reassembling, just keep your torque consistent throughout the build.
Old Aug 17, 2019 | 02:13 PM
I usually Heli-Coil em and use the torque appropriate to that size hardware (10mm)... which as stated above is in the 40 - 45 ft-lb range.
Old Aug 17, 2019 | 03:44 PM
kenbob's Avatar
Engine: 305 LB9
Borg Warner and tremec both say 23-25 ft.lbs otherwise you'll push out all the sealant
Old Aug 18, 2019 | 12:33 AM
jmd's Avatar
jmd
You can't accomplish that at double any of the torque measurements mentioned in this thread. The (relatively) rough machined surfaces of the main case and extension housing allow for RTV to fill in small gaps. And the torque levels I'm referencing are not able to compress an aluminum case surface sufficient to prevent that from happening.
Aluminum has a different coefficient of expansion than steel. A case that will expand and contract a bit with heating and cooling needs a conservative clamping force; nothing more. In the case of the T5, the case assembly is more than adequately retained with the bolts. What you would accomplish were you to grossly overtorque the extension housing bolts is stripping thread, or cracking case castings.
irockid43
Sep 2, 2014 11:24 PM
tonys91rs
Apr 26, 2012 05:45 PM
husker2733
Mar 5, 2012 07:15 AM
akmusclecar
Jun 20, 2009 03:18 AM
DARKmj16
Feb 8, 2008 01:31 AM
