91 camaro axle swap from 2000 z28
Hi guys i have a question thats probably been asked alot but cant find the answer so heres the question can i swap a rear axle from a 2000 z28 into a 91 v6 the car is in the process of getting a new motor so i want to beef up the rear end a little any info would be great thx.
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Re: 91 camaro axle swap from 2000 z28
No.
4th gen rear ends I think are 2 inches longer. So 64" total while 3rd gens are 62" from flange to flange.
It's best to stick with 3rd gen rear ends to 3rd gen rear ends. But all the internals can be used. I.E. differential [granted the spline count on the axles are the same], brake parts [drum brakes]...etc.
Actually...I'm not sure what you mean by "rear axle." Drive axle or driven axle???
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
No? What world do you live in?
Yes you can, as Rocketyman said your wheels will stick out a bit farther and from my experience just a bit from the fender lip. Its all fine if you are planning to run 4th gen wheels. Just expect the wheels to stick out with stock 3rd gen wheels. A search will give some pictures and results from this.
If you want to beef up the 10 bolt or keep it alive, eliminate wheel hop, weld the axle tubes, girdle, etc.
Thx for the info well the car is geting a supercharged ls1 4l60e I think not sure this is a friends car but if in good shape is it a good buy for 250 complete end to end
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Sorry it has a 305 I thought v6 and the weaker manual trans so there is no benifet then huh even though its the more powerful ls ? So spend the money elsewhere thx guys
Why would you want your rear wheels to stick out and look ghetto??
Lemme tell you...once one of your buddies notices a SMALL minor detail about your wheels sticking out, it bugs the SHHT outta you. And if you wanna run 4th gen wheels, you'd then have to mess with the front hubs...that's if you even like 4th gen salad slicers on your car which look whack...on a 3rd gen.
"No," if you wanna keep the look of your car--and your sanity.
Please do some research and see that they stick out not as bad as you think.
Here I did the search for you since you will probably won't...
https://www.thirdgen.org/forums/post...568-post4.html
and
https://www.thirdgen.org/forums/post...673-post1.html
Its not that bad, and not ghetto. Its fine until you can find some wheels you want to run. Who stays with stock wheels when their making a build? Who said anything about going with stock 4th gen wheels?
Its a shame you passed on the rear, I plan to ditch my 9 bolt for a 4th gen 10 bolt when I get the chance, I hate running spacers on aftermarket wheels.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
[QUOTE=RocketyMan;5110252]No.
actually four inches wider.two on each side.
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
Hey syn 77 I totally did this. It was a direct bolt in plus some minor brake and ebrake work. Yep it sticks out 2 inches which I knew it would. I personally love it and looks more aggressive. I had after market mags on my old drum set up17" they work fine on the 4th gen rear out of a 2000 ta. Disc brakes from a 99 z28. I don't remember having any great issues doing this swap but message me and I can help you out.
So what did u have to do to hook up the disk brakes and E brake?
