3.73s in a BW 9 bolt
Old Mar 7, 2003 | 11:04 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
what is needed to go from 2.77 to 3.73? obviously the gears, a carrier? what else. i have no clue, also what books are there that would help give me some insight into a gear swap, to do it PROPERLY!!
thanks alot.
this is one of my upcomin mods.
matt
Old Mar 7, 2003 | 11:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need a carrier and a set of gears, and all the bearings and shims.
But first, you need a wheelbarrow full of $$$$. I doubt you can get just the parts alone to do that, for less than $750.
Old Mar 7, 2003 | 12:10 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
750 bucks for gears for a 9 bolt!?!?
what happened to like 400? thats a rip off.
do they bearings and shims usually come with the gear/carrier set?
Old Mar 7, 2003 | 12:25 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
$750 is for the carrier and gear set, a 3.73 ring gear wont fit on the 2.77 carrier, so you have to buy both. Just go to www.9bolt.com , all the prices are on there.
Old Mar 7, 2003 | 01:57 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
thanks miles!
maybe someday soon youll get an order from me. just curious, why are 9 bolt parts so expensive? arent 10 bolt parts quite a bit cheaper?
Old Mar 7, 2003 | 05:19 PM
Drakar's Avatar
9 bolts are expensive because they where a very limited run in NA, they where in the 86-89 birds and in the 87-89 or 90 not sure but only a few years, where as the 10 bolt everyone and there dog has one as a fake tree in there back yard.
Old Mar 7, 2003 | 07:04 PM
Breadfan's Avatar
if you can find a used series 3 carrier you can save some money . But 800.00 is still cheapier than a 9 inch or a 12bolt .
Old Mar 11, 2003 | 02:14 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
How much stronger are the 9 bolts?were talking 7 5/8 verses 7 3/4.Im thinking the cost far out weighs the strength.I would go with a 10 bolt, plentifull and cheap.If im wrong please somebody explain it to me.
Old Mar 12, 2003 | 11:01 PM
toomanycamaros's Avatar
Look on ebay right now,a guy is selling a 9-Bolt Borg Warner posi carrier.They are the cone type,way better than the 10 bolt eaton carrier.I just picked up a complete rear disc,eibach springs and a whole lotta parts off an 89 GTA for $200 I even got an aluminum driveshaft!!
Old Mar 13, 2003 | 06:08 PM
Breadfan's Avatar
Goto 9bolt.com
Old Mar 15, 2003 | 08:04 AM
ausrs's Avatar
9 bolt parts are more expensive than 10 bolt coz they have to be imported to usa ......the housing was a limited run and GM stopped importing them for cost reasons HOWEVER they are still the performance( read stronger ) option on a camaro/firebird ...........would you take a 350 out and fit a 305 tbi motor ????????
like us aus guys importing camaro /trans am parts from usa we are affected by monetary exchange rates and the aus $ has now come back up .which is good for us guys in aus as things get cheaper BUT worse for you as it will make things more expensive
and btw you cannot get a NEW ring and pinion in aus for a 9 bolt for much less than the price you are hoping to pay njitiroc and then you have to pay freight /import duties to get them into usa .....
the reverse happens to us in aus
a ratio change on a 10 bolt costs us around $1800 !!!!!!!!!!!
Old Oct 28, 2003 | 09:57 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I've got my bird in the shop right now getting 3.73's put in my 9 bolt since i shelled the 3.45's. It ain't cheap I'll be the first to tell ya. the gear fit in my carrier since it's originally 3.45, and I'm still spening $1059.16. Thats for labor, oil, a new diff cover(old one had a hole shot through it), Ring&Pinion, Shims, Axle seals&bearings. So with a carrier, look at spending even more.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Jlanz55
Sep 6, 2015 07:28 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
