Grinding Into Reverse!?!?
Old Mar 17, 2003 | 04:04 PM
91 Camaro Z28's Avatar
Ok people, i just did my T-5 swap, and about 5 miles of driving after i got done blew my hydraulic line. So i got the parts and replaced all of that. and now, my clutch doesnt seem to be catching as close to the floor as it did, and it grinds into reverse 50% of the time. Any ideas as to what the culprit may be? If the hydraulic fluid got on the flywheel or clutch assembly after it blew up, would that mess anything up? Or would it just burn off after a few miles. I've been driving it the past 3 days with no major problems besides the grinding into reverse and the delayed catching- please help me people-- its so close to being perfect!!:hail:
Old Mar 17, 2003 | 04:53 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
in every t5 equipped car u must go to a forward gear like 4th to stop all the gears in teh trany from moving, then u can go to reverse. its cause reverse is not a synchronized gear
Old Mar 17, 2003 | 04:55 PM
so even if i'm at a complete stop after slowing down from going forward, i need to put it in 4th for a second? then it'll go into reverse?
Old Mar 17, 2003 | 11:35 PM
JesasaurusRex's Avatar
Yup my car 2, 4th then into reverse, problem solved.
Old Mar 18, 2003 | 08:02 AM
hmm, thats strange- could it be possible that my tranny is a little low on gear oil and is grinding a little bit?
Old Mar 18, 2003 | 10:16 AM
No, he explained the reason already this is the last post ill be doin on ur subject, the answers already stated re read.
Old May 7, 2003 | 12:13 PM
WildStreak's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8L V6
Transmission: TH-700R4
I actually have to come to a full stop, put it in 1st gear, barely let the clutch out just to let the car roll like 1", then it slides right into reverse..any other way, and i'm in for a grinding. lol
Old May 22, 2003 | 01:01 PM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
hah - I've had my camaro for 6 years and always just thought the reverse synchro was bad - but yeah 4th to reverse always works fine
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
84redta
Sep 19, 2015 09:58 AM
