Can I fit a 10 bolt Posi from a Turbo Trans Am
into a 305 auto ?
The gears on this are 3.0x with drums from a 1980 Turbo trans Am, is this a straight swap onto my '89 Camaro?
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Yes any 9 or 10 bolt from any 3rd gen will swap into any other thirdgen. If the brakes are different you may need to change a few things like prop valve.
I am almost positive that the Turbo Trans Am never came with a 10-bolt. I am pretty sure it came with a 9-bolt.
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
he said from a 1980 Turbo 301 TA
the 1989 TTA came with a 9 bolt
The rearend from an 80 turbo-ta should be 8.5/10 bolt[I have one from an 81 w/3.08,disc posi] it is a much stonger rear than a 7.5/7.625 that came in 82 -up f bodies,there was a nine bolt available but parts are exspensive. If the width is right, you can make anything fit anything by moving the spring hangers or adapting if going from coils to leafs or vice - versa.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
