flywheel question 305
Im having some trouble with my 85 camaro. I had built a 355 with a roller and it ran strong but I just broke a connecting rod so i dont have a car. I am 16, dont have any money and need to get to work. A friend at the local junkyard can give me a 4barrel 305. I wanted to know if i could use the flywheel from my 72 350 thats in it now. Do they have the same bolt pattern? I havent pulled my motor out yet. All or my parts have less than 2500 miles on them so i want to use my pressure plate and clutch again at least untili get another motor built.
Thanks, Dave
Thanks, Dave
Ok I looked at the 305 again and it has a 2 peice rear seal. I think the end of the crank is the same. I have one more question though. Will i have any problems as a result of the dip stick being on the passenger side rather than the drivers side? Will the dipstick interfere with my headers, They are for an 82-92 camaro V8. The motor is not specified. They are from hedman and worked fine with the 350.
Thanks a bunch
Dave
Thanks a bunch
Dave
It had a flex plate on it because it came out of an automatic, I was going to put my flywheel on it anyways because my car is standard. I will be able to use my starter and clutch and pressure plate.
Maybe I was misunderstood. I thought i might have problems bolting my flywheel to the 305 crank because some are not the same. Somthing like a metric style and a standard style. I found out that you can tell which is which by what rear main seal the motor has. Both motors have a 2 piece seal so i am all set.
Thanks again guys.
Dave
Thanks again guys.
Dave
BlackphantomZ28
Aug 31, 2015 10:29 AM
